I tried codeblocks but it would not compile.
#include <stdio.h>
int main()
printf("Hello world");
how to use Code::Blocks IDE for C++ or python
Re: how can I program for the raspberry pi 2/raspbian?
and pls post
- how you try to compile and
- what the error msg was
because here i can edit
nano hello.cpp include your above code example, save, and compile with
g++ -std=c++0x hello.cpp -ohello
and run it with
./hello
so, your code is very good!
now for Code::Blocks IDE must find a manual
http://www.codeblocks.org/user-manual
or you must be lucky,
open new project
as / console application / C++ /
give project name / path /
comes with its ready hello world example code
compile /run ( press [F9] )
voilà
looks like http://kll.engineering-news.org/kllfusi ... #example4c
can you pls change the question / header line to:
"how to use Code::Blocks IDE for C++"
and run it with
./hello
open new project
voilà
