PeeWee
Starting Arch Linux
Fri Jul 20, 2012 10:36 am
I want to try the Arch Linux distro on my Pi, but how do you do it?
I have prepared my SD card, connected Pi to the TV and powered up. After the initial boot, I logged in as root, but then all I got was the command prompt.
Is there a command to start Arch so that it opens with a GUI like Debian?
Or what do I do to start using Arch?
Is it a command line interface only?
Regards
PeeWee
obarthelemy
Re: Starting Arch Linux
Fri Jul 20, 2012 11:58 am
Arch by default only has the command line. You can of course install several GUIs.
They have an excellent wiki: https://wiki.archlinux.org/ but honestly, if you're lost already, you might want to start with debian/raspbian/puppy and get your sea legs with those before moving on to arch which does a lot less hand-hoding.
PeeWee
Sat Jul 21, 2012 6:53 am
Thanks for the help.
I shall check the Arch website and see what is involved in installing a GUI. In the meantime I shall be running Debian and also look at Puppy.
Regards
PeeWee
