coskukoz
Circuit Problem
Thu Aug 06, 2015 2:28 pm
Hi guys
I used to display 0 - 3.3V by using MCP3008 and Pi. My sensors are 0 - 10V and I draw a circuit (picture below here) to divide voltage. According to my calculations it should work but it shows wrong. When sensor is 5V, I see 4,5V on the screen. And it should be 0 - 10V but after 8.8V it reach 1023. I dont understand what is problem. If someone has idea plase guys let me know.
The circuit
circuit
The code
import spidev
import time
import os
import urllib
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
spi = spidev.SpiDev()
spi.open(0,0)
def ReadChannel(channel):
  adc = spi.xfer2([1,(8+channel)<<4,0])
  data = ((adc[1]&3) << 8) + adc[2]
  return data
def ConvertVolts(data,places):
  volts = (data * 10) / float(1023)
  volts = round(volts,places)
  return volts
def ConvertTemp(data,places):
  temp = ((data * 330)/float(1023))-50
  temp = round(temp,places)
  return temp
sensor1_channel = 0
sensor2_channel = 1
sensor3_channel = 2
sensor4_channel = 3
sensor5_channel = 4
sensor6_channel = 5
sensor7_channel = 6
sensor8_channel = 7
delay = 5
GPIO.setwarnings(False)
GPIO.setup(5, GPIO.IN)
GPIO.setup(6, GPIO.IN)
GPIO.setup(13, GPIO.IN)
GPIO.setup(19, GPIO.IN)
GPIO.setup(26, GPIO.IN)
GPIO.setup(16, GPIO.IN)
GPIO.setup(20, GPIO.IN)
GPIO.setup(21, GPIO.IN)
while True:
  foldtime = time.time()
  fnewtime = time.time()
  fstore = 10.0                                 # second
  while True:
    fdtime = fnewtime-foldtime
    digital1 = GPIO.input(5)
    digital2 = GPIO.input(6)
    digital3 = GPIO.input(13)
    digital4 = GPIO.input(19)
    digital5 = GPIO.input(26)
    digital6 = GPIO.input(21)
    digital7 = GPIO.input(20)
    digital8 = GPIO.input(16)
    if digital1 == 1:
     digital1 = 'ON'
    else:
      digital1 = 'OFF'
    if digital2 == 1:
     digital2 = 'ON'
    else:
      digital2 = 'OFF'
    if digital3 == 1:
     digital3 = 'ON'
    else:
      digital3 = 'OFF'
    if digital4 == 1:
     digital4 = 'ON'
    else:
      digital4 = 'OFF'
    if digital5 == 1:
     digital5 = 'ON'
    else:
      digital5 = 'OFF'
    if digital6 == 1:
     digital6 = 'ON'
    else:
      digital6 = 'OFF'
    if digital7 == 1:
     digital7 = 'ON'
    else:
      digital7 = 'OFF'
    if digital8 == 1:
     digital8 = 'ON'
    else:
      digital8 = 'OFF'
    sensor1_level = ReadChannel(sensor1_channel)
    sensor1_volts = ConvertVolts(sensor1_level,2)
    sensor2_level = ReadChannel(sensor2_channel)
    sensor2_volts = ConvertVolts(sensor2_level,2)
    sensor3_level = ReadChannel(sensor3_channel)
    sensor3_volts = ConvertVolts(sensor3_level,2)
    sensor4_level = ReadChannel(sensor4_channel)
    sensor4_volts = ConvertVolts(sensor4_level,2)
    sensor5_level = ReadChannel(sensor5_channel)
    sensor5_volts = ConvertVolts(sensor5_level,2)
    sensor6_level = ReadChannel(sensor6_channel)
    sensor6_volts = ConvertVolts(sensor6_level,2)
    sensor7_level = ReadChannel(sensor7_channel)
    sensor7_volts = ConvertVolts(sensor7_level,2)
    sensor8_level = ReadChannel(sensor8_channel)
    sensor8_volts = ConvertVolts(sensor8_level,2)
    if fdtime >= fstore:
      foldtime = fnewtime
      googlepage = "https://script.google.com/macros/s/"
      mygooglekey = "AKfycag8ıtng1231byDLLxRSLBLLqdadekqtjr_0wSgFJKfqRassd526s21QtLeO9oJMhUqzFBs"
      wtime = time.strftime("%d/%m/%Y %H:%M:%S")
      content = urllib.urlopen("%s%s/exec?DATE=%s&Sensor1=%s&Sensor2=%s&Sensor3=%s&Sensor4=%s&Sensor5=%s&Sensor6=%s&Sensor7=%s&Sensor8=%s&Digital1=%s&Digital2=%s&Digital3=%s&Digital4=%s&Digital5=%s&Digital6=%s&Digital7=%s&Digital8=%s" %(googlepage, mygooglekey, wtime, sensor1_volts, sensor2_volts, sensor3_volts, sensor4_volts, sensor5_volts, sensor6_volts, sensor7_volts, sensor8_volts, digital1, digital2, digital3, digital4, digital5, digital6, digital7, digital8)).read()
      print "-----------------------------------------------------------------------------"
      print(" Sensor-1            Sensor-2         Sensor-3          Sensor-4         Sensor-5            Sensor-6         Sensor-7          Sensor-8")
      print(" {} - ({}V)        {} - ({}V)      {} - ({}V)      {} - ({}V)          {} - ({}V)          {} - ({}V)     {} - ({}V)        {} - ({}V)".format(sensor1_level,sensor1_volts,sensor2_level,sensor2_volts,sensor3_level,sensor3_volts,sensor4_level,sensor4_volts,sensor5_level,sensor5_volts,sensor6_level,sensor6_volts,sensor7_level,sensor7_volts,sensor8_level,sensor8_volts))
      print(" Digital-1            Digital-2         Digital-3          Digital-4         Digital-5            Digital-6         Digital-7          Digital-8")
      print(" {}                  {}                  {}                 {}                    {}                    {}                {}                 {} ".format(digital1,digital2,digital3,digital4,digital5,digital6,digital7,digital8))
time.sleep(delay)
cactiapps.blogspot.com
coskukoz
Re: Circuit Problem
Fri Aug 07, 2015 8:57 am
Guys problem was Grounds. MCP3008 has 2 types of grounds which are called 'digital ground' and 'analog ground'. I connected them together. It's a mistake. Right way is: connect digital ground to Pi and connect analog ground to sensors. That's all. Now it's working. :ugeek:
KLL
Re: Circuit Problem
Fri Aug 07, 2015 12:19 pm
but actually according
https://www.adafruit.com/datasheets/MCP3008.pdf and
https://learn.adafruit.com/reading-a-an ... -a-mcp3008 see FIGURE 6-5
the grounds should be connected.
but how about Vref? connected to 3v3 gives
10(V) * 1024 * 470/(1000+470) *3.3 = 992 => 9.68V
