I used to display 0 - 3.3V by using MCP3008 and Pi. My sensors are 0 - 10V and I draw a circuit (picture below here) to divide voltage. According to my calculations it should work but it shows wrong. When sensor is 5V, I see 4,5V on the screen. And it should be 0 - 10V but after 8.8V it reach 1023. I dont understand what is problem. If someone has idea plase guys let me know.
The circuit The code
import spidev
import time
import os
import urllib
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
spi = spidev.SpiDev()
spi.open(0,0)
def ReadChannel(channel):
adc = spi.xfer2([1,(8+channel)<<4,0])
data = ((adc[1]&3) << 8) + adc[2]
return data
def ConvertVolts(data,places):
volts = (data * 10) / float(1023)
volts = round(volts,places)
return volts
def ConvertTemp(data,places):
temp = ((data * 330)/float(1023))-50
temp = round(temp,places)
return temp
sensor1_channel = 0
sensor2_channel = 1
sensor3_channel = 2
sensor4_channel = 3
sensor5_channel = 4
sensor6_channel = 5
sensor7_channel = 6
sensor8_channel = 7
delay = 5
GPIO.setwarnings(False)
GPIO.setup(5, GPIO.IN)
GPIO.setup(6, GPIO.IN)
GPIO.setup(13, GPIO.IN)
GPIO.setup(19, GPIO.IN)
GPIO.setup(26, GPIO.IN)
GPIO.setup(16, GPIO.IN)
GPIO.setup(20, GPIO.IN)
GPIO.setup(21, GPIO.IN)
while True:
foldtime = time.time()
fnewtime = time.time()
fstore = 10.0 # second
while True:
fdtime = fnewtime-foldtime
digital1 = GPIO.input(5)
digital2 = GPIO.input(6)
digital3 = GPIO.input(13)
digital4 = GPIO.input(19)
digital5 = GPIO.input(26)
digital6 = GPIO.input(21)
digital7 = GPIO.input(20)
digital8 = GPIO.input(16)
if digital1 == 1:
digital1 = 'ON'
else:
digital1 = 'OFF'
if digital2 == 1:
digital2 = 'ON'
else:
digital2 = 'OFF'
if digital3 == 1:
digital3 = 'ON'
else:
digital3 = 'OFF'
if digital4 == 1:
digital4 = 'ON'
else:
digital4 = 'OFF'
if digital5 == 1:
digital5 = 'ON'
else:
digital5 = 'OFF'
if digital6 == 1:
digital6 = 'ON'
else:
digital6 = 'OFF'
if digital7 == 1:
digital7 = 'ON'
else:
digital7 = 'OFF'
if digital8 == 1:
digital8 = 'ON'
else:
digital8 = 'OFF'
sensor1_level = ReadChannel(sensor1_channel)
sensor1_volts = ConvertVolts(sensor1_level,2)
sensor2_level = ReadChannel(sensor2_channel)
sensor2_volts = ConvertVolts(sensor2_level,2)
sensor3_level = ReadChannel(sensor3_channel)
sensor3_volts = ConvertVolts(sensor3_level,2)
sensor4_level = ReadChannel(sensor4_channel)
sensor4_volts = ConvertVolts(sensor4_level,2)
sensor5_level = ReadChannel(sensor5_channel)
sensor5_volts = ConvertVolts(sensor5_level,2)
sensor6_level = ReadChannel(sensor6_channel)
sensor6_volts = ConvertVolts(sensor6_level,2)
sensor7_level = ReadChannel(sensor7_channel)
sensor7_volts = ConvertVolts(sensor7_level,2)
sensor8_level = ReadChannel(sensor8_channel)
sensor8_volts = ConvertVolts(sensor8_level,2)
if fdtime >= fstore:
foldtime = fnewtime
googlepage = "https://script.google.com/macros/s/"
mygooglekey = "AKfycag8ıtng1231byDLLxRSLBLLqdadekqtjr_0wSgFJKfqRassd526s21QtLeO9oJMhUqzFBs"
wtime = time.strftime("%d/%m/%Y %H:%M:%S")
content = urllib.urlopen("%s%s/exec?DATE=%s&Sensor1=%s&Sensor2=%s&Sensor3=%s&Sensor4=%s&Sensor5=%s&Sensor6=%s&Sensor7=%s&Sensor8=%s&Digital1=%s&Digital2=%s&Digital3=%s&Digital4=%s&Digital5=%s&Digital6=%s&Digital7=%s&Digital8=%s" %(googlepage, mygooglekey, wtime, sensor1_volts, sensor2_volts, sensor3_volts, sensor4_volts, sensor5_volts, sensor6_volts, sensor7_volts, sensor8_volts, digital1, digital2, digital3, digital4, digital5, digital6, digital7, digital8)).read()
print "-----------------------------------------------------------------------------"
print(" Sensor-1 Sensor-2 Sensor-3 Sensor-4 Sensor-5 Sensor-6 Sensor-7 Sensor-8")
print(" {} - ({}V) {} - ({}V) {} - ({}V) {} - ({}V) {} - ({}V) {} - ({}V) {} - ({}V) {} - ({}V)".format(sensor1_level,sensor1_volts,sensor2_level,sensor2_volts,sensor3_level,sensor3_volts,sensor4_level,sensor4_volts,sensor5_level,sensor5_volts,sensor6_level,sensor6_volts,sensor7_level,sensor7_volts,sensor8_level,sensor8_volts))
print(" Digital-1 Digital-2 Digital-3 Digital-4 Digital-5 Digital-6 Digital-7 Digital-8")
print(" {} {} {} {} {} {} {} {} ".format(digital1,digital2,digital3,digital4,digital5,digital6,digital7,digital8))
time.sleep(delay)
