5v to 3.3v GPIO
Posted: Sun Aug 02, 2015 8:46 am
by scraff
Hi all. Just a quick question. I have searched and searched but not found a definite answer.
I have some modules designed for Arduino that output 5v. Obviously can't connect these directly to RPi's gpio pins.
I've read in various places to just put a 1k resistor in between the module and the gpio input.
Others say u have to use a 2k and 3k to split the voltage. I know this splits the voltage at a 3:2 ratio.
Is just putting one 1k resistor in there enough? What does this do exactly compared to the voltage splitter?
Re: 5v to 3.3v GPIO
Posted: Sun Aug 02, 2015 8:55 am
by joan
I believe using a pair of resistors to form a voltage divider will be safer.
A single resistor will limit the current flow. I believe the idea is to limit the 5V current flow to something less than 0.5 mA which some believe may safely be handled by the Pi's internal circuitry.
Re: 5v to 3.3v GPIO
Posted: Sun Aug 02, 2015 9:04 am
by PeterO
joan wrote:I believe using a pair of resistors to form a voltage divider will be safer.
It's not hard to work out the actual current flow:
Assuming the GPIO input is clamped to 3.3V, and the external device's output is 5V, then the 1000 ohm resistor will have 5V-3.3V = 1.7V across it, leading to a current flow of 1.7/1000 = 1.7mA into the GPIO pin.
PeterO
Re: 5v to 3.3v GPIO
Posted: Sun Aug 02, 2015 9:06 am
by scraff
Thanks Joan.
I had kind of assumed this but really wasn't sure.
One more question: is splitting the voltage using 2 resistors just as good as a logic level converter (eg the adafruit one)? Is a logic level converter overkill?
Re: 5v to 3.3v GPIO
Posted: Sun Aug 02, 2015 9:13 am
by joan
scraff wrote:Thanks Joan.
I've never used a device which needed more than a pair of resistors, i.e. they were all Pi inputs. The level converters may be targeted at devices where a single line is used both as an input and an output.
