coskukoz
Some GPIO Pins make Raspberry Pi Shut Down
Tue Jul 28, 2015 12:33 pm
Hi guys,
I use MCP3008 and I read analog sensor with it. Now I need to read some digital sensors. I wrote my code but when I use some GPIO pins Raspberry Pi Shut Down by itself. I did not understand why. If you guys know why please let me know.
This is my code:
#!/usr/bin/python
import spidev
import time
import os
import urllib
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
spi = spidev.SpiDev()
spi.open(0,0)
def ReadChannel(channel):
  adc = spi.xfer2([1,(8+channel)<<4,0])
  data = ((adc[1]&3) << 8) + adc[2]
  return data
def ConvertVolts(data,places):
  volts = (data * 3.3) / float(1023)
  volts = round(volts,places)
  return volts
def ConvertTemp(data,places):
  temp = ((data * 330)/float(1023))-50
  temp = round(temp,places)
  return temp
sensor1_channel = 0
sensor2_channel = 1
sensor3_channel = 2
sensor4_channel = 3
sensor5_channel = 4
sensor6_channel = 5
sensor7_channel = 6
sensor8_channel = 7
delay = 5
while True:
  foldtime = time.time()
  fnewtime = time.time()
  fstore = 10.0                                 # second
  while True:
    fdtime = fnewtime-foldtime
    GPIO.setwarnings(False)
    GPIO.setup(5, GPIO.IN)
    GPIO.setup(6, GPIO.IN)
    GPIO.setup(13, GPIO.IN)
    GPIO.setup(19, GPIO.IN)
    GPIO.setup(26, GPIO.IN)
    #GPIO.setup(12, GPIO.IN)
    GPIO.setup(16, GPIO.IN)
    #GPIO.setup(25, GPIO.IN)
    #digital1 = GPIO.input(5)
    #digital2 = GPIO.input(6)
    #digital3 = GPIO.input(13)
    #digital4 = GPIO.input(19)
    #digital5 = GPIO.input(26)
    #digital6 = GPIO.input(12)
    #digital7 = GPIO.input(16)
    #digital8 = GPIO.input(20)
    sensor1_level = ReadChannel(sensor1_channel)
    sensor1_volts = ConvertVolts(sensor1_level,2)
    sensor2_level = ReadChannel(sensor2_channel)
    sensor2_volts = ConvertVolts(sensor2_level,2)
    sensor3_level = ReadChannel(sensor3_channel)
    sensor3_volts = ConvertVolts(sensor3_level,2)
    sensor4_level = ReadChannel(sensor4_channel)
    sensor4_volts = ConvertVolts(sensor4_level,2)
    sensor5_level = ReadChannel(sensor5_channel)
    sensor5_volts = ConvertVolts(sensor5_level,2)
    sensor6_level = ReadChannel(sensor6_channel)
    sensor6_volts = ConvertVolts(sensor6_level,2)
    sensor7_level = ReadChannel(sensor7_channel)
    sensor7_volts = ConvertVolts(sensor7_level,2)
    sensor8_level = ReadChannel(sensor8_channel)
    sensor8_volts = ConvertVolts(sensor8_level,2)
    if fdtime >= fstore:
      foldtime = fnewtime
      googlepage = "https://script.google.com/macros/s/"
      mygooglekey = "AKfycbyDLsfafsafasfLxRSLBLLqekqtjr_0wSgFJKfqR6s2afsfaasfas1QtLeO9oJMhUqzFBs"
      wtime = time.strftime("%d/%m/%Y %H:%M:%S")
      content = urllib.urlopen("%s%s/exec?DATE=%s&Sensor1=%s&Sensor2=%s&Sensor3=%s&Sensor4=%s&Sensor5=%s&Sensor6=%s&Sensor7=%s&Sensor8=%s" %(googlepage, mygooglekey, wtime, sensor1_volts, sensor2_volts, sensor3_volts, sensor4_volts, sensor5_volts, sensor6_volts, sensor7_volts, sensor8_volts)).read()
      print "-----------------------------------------------------------------------------"
      print(" Sensor-1            Sensor-2         Sensor-3          Sensor-4         Sensor-5            Sensor-6         Sensor-7          Sensor-8")
      print(" {} - ({}V)        {} - ({}V)      {} - ({}V)      {} - ({}V)          {} - ({}V)          {} - ({}V)     {} - ({}V)        {} - ({}V)".format(sensor1_level,sensor1_volts,sensor2_level,sensor2_volts,sensor3_level,sensor3_volts,sensor4_level,sensor4_volts,sensor5_level,sensor5_volts,sensor6_level,sensor6_volts,sensor7_level,sensor7_volts,sensor8_level,sensor8_volts))
      #print(" Digital-1            Digital-2         Digital-3          Digital-4         Digital-5            Digital-6         Digital-7          Digital-8")
      #print(" {}         {}       {}       {}          {}          {}     {}         {} )".format(digital1,digital2,digital3,digital4,digital5,digital6,digital7,digital8))
time.sleep(delay)
cactiapps.blogspot.com
joan
Re: Some GPIO Pins make Raspberry Pi Shut Down
Tue Jul 28, 2015 1:33 pm
Could you post a photo of your MCP3008 set-up?
It is more likely there is something wrong with the hardware set-up.
Remember the Pi's gpios should only be exposed to a maximum of 3V3. If you are powering the MCP3008 from 5V you may be feeding 5V to the Pi's MISO gpio.
coskukoz
Tue Jul 28, 2015 2:23 pm
I took photos. Maybe you can see if there is something wrong. But as I said It is working if I dont use digital inputs on GPIO.
gordon77
Tue Jul 28, 2015 2:41 pm
What do you mean by using digital inputs on GPIO ? How are they connected ?
coskukoz
Tue Jul 28, 2015 2:52 pm
I didn`t connect Digital Inputs to the GPIO port yet but I use pin19,21,23,24 for MCP3008 at the momment. And when I just use code below it works well but when I use the code that I posted at the first it makes shut down. I hope I can explain :(
#!/usr/bin/python
import spidev
import time
import os
import urllib
spi.open(0,0)
  return data
  return volts
  return temp
sensor1_channel = 0
sensor2_channel = 1
sensor3_channel = 2
sensor4_channel = 3
sensor5_channel = 4
sensor6_channel = 5
sensor7_channel = 6
sensor8_channel = 7
delay = 5
while True:
  while True:
      foldtime = fnewtime
      mygooglekey = "AKfycbyDLLxRSLBLLqsadfasdfekqtjr_0wSgFJKfqfsasfR6s21QtLfsafaseO9oJMhUqzFBs"
      print("{} - ({}V)        {} - ({}V)      {} - ({}V)      {} - ({}V)          {} - ({}V)          {} - ({}V)     {} - ({}V)        {} - ({}V)".format(sensor1_level,sensor1_volts,sensor2_level,sensor2_volts,sensor3_level,sensor3_volts,sensor4_level,sensor4_volts,sensor5_level,sensor5_volts,sensor6_level,sensor6_volts,sensor7_level,sensor7_volts,sensor8_level,sensor8_volts))
time.sleep(delay)
gordon77
Tue Jul 28, 2015 3:03 pm
I am not sure if it will make any difference but try moving this section out of the loop and near the beginning of the programme so it only runs once
coskukoz
Tue Jul 28, 2015 3:18 pm
Oh yes it`s working now. Thank you very much :)
The code is:
#!/usr/bin/python
import spidev
import time
import os
import urllib
spi.open(0,0)
  return data
  return volts
  return temp
sensor1_channel = 0
sensor2_channel = 1
sensor3_channel = 2
sensor4_channel = 3
sensor5_channel = 4
sensor6_channel = 5
sensor7_channel = 6
sensor8_channel = 7
delay = 5
while True:
  while True:
    digital6 = GPIO.input(16)
    digital7 = GPIO.input(20)
    digital8 = GPIO.input(21)
      foldtime = fnewtime
time.sleep(delay)
gordon77
Tue Jul 28, 2015 3:25 pm
Good News. Not something I have seen before, and not sure why it would crash the Pi but I am pleased it fixed it.
Gordon77
