jsmith0012
DS3231 hwclock not working right
Sun Jul 12, 2015 9:06 pm
im trying ti use a DS3231 hwclock on a Pi 2 and i think i got it all working right but its not saving the time properly.
i see the RTC being setup in the dmeg
[email protected] ~ $ dmesg | grep rtc
[ 4.596119] rtc-ds1307 1-0068: SET TIME!
[ 4.656566] rtc-ds1307 1-0068: rtc core: registered ds3231 as rtc0
but
[email protected] ~ $ sudo hwclock -r
hwclock: The Hardware Clock registers contain values that are either invalid (e.g. 50th day of month) or beyond the range we can handle (e.g. Year 2095).
so i checked the data that is stored in the registers of the rtc.
[email protected] ~ $ sudo cat /sys/class/i2c-adapter/i2c-1/1-0068/rtc/rtc0/since_epoch
3029529709
the time is not set on the clock. so i go ahead and set the time to the rtc clock.
[email protected] ~ $ date
Sun Jul 12 21:02:47 UTC 2015
[email protected] ~ $ sudo hwclock -w
Sun 12 Jul 2015 21:02:59 UTC -0.497060 seconds
1436734984
but after reboot the clock is back up to that huge number and im back to getting the same error message.
i have replaced the battery one already ... no idea what to do :(
dentex
Re: DS3231 hwclock not working right
Wed Jul 22, 2015 4:21 pm
Same here.
It's a PITA, this stuff brakes every once in a while, after upgrading the RPi.
One of my projects with the Raspberry Pi:
(Raspberry) Pi Aquarium Controller: https://github.com/dentex/piac
dentex
Wed Jul 22, 2015 5:07 pm
After a
sudo rpi-update
and a reboot, it seems that in "/boot/config.txt"
you need
dtoverlay=i2c-rtc,ds1307
instead of
dtoverlay=ds1307-rtc
But please double check this.
drgeoff
Wed Jul 22, 2015 5:19 pm
The moral of this is "Don't run rpi-update unless you really know what you are doing.".
dentex
Wed Jul 22, 2015 5:22 pm
I ran rpi-update after the issue, to have a new known working configuration for my DS1307.
I suspect that just an apt-get upgrade broke something.
Return to “Beginners”
