Can
VGA Monitor
Thu Jul 09, 2015 1:33 pm
My old monitor is a VGA , how i use it for raspi2 ?
RogerW
Re: VGA Monitor
Thu Jul 09, 2015 1:58 pm
Joe Schmoe
Re: VGA Monitor
Thu Jul 09, 2015 2:43 pm
Two comments:
  1. I don't understand why anybody continues to use or recommend any of the FooBaz Electronics, Ltd. "HDMI to VGA converters" when Gert's "666" version exists. As far as I can tell, Gert's board is cheaper, better (more effective) and much more reliable (i.e., actually likely to work). From what I can tell, all of the various "FooBaz" converters are nothing but trouble.
  2. The best way to use a VGA monitor with the Pi is using a real computer and VNC (or RDP is you are so inclined) to access the Pi. Trust me on this.
Can
Re: VGA Monitor
Thu Jul 09, 2015 4:21 pm
RogerW wrote:I use something like this
http://www.ebay.co.uk/itm/HDMI-to-VGA-S ... 258ad6344c
I think , ı will buy it.But i hear on web , this devices not gives screen.
Re: VGA Monitor
Thu Jul 09, 2015 4:36 pm
Read the Pictorial Buying Guide
viewtopic.php?f=91&t=83446
Retired disgracefully.....
......to a more gentile life !
pluggy
Re: VGA Monitor
Thu Jul 09, 2015 4:56 pm
Joe Schmoe wrote:Two comments:
The problem with Gert's board is that you need to sacrifice the all the GPIO to use it. The GPIO is arguably the most useful part of the Pi.
Buy a second hand slightly up market VGA monitor that also has a DVI input. They can be had very reasonable on Fleabay.
W. H. Heydt
Re: VGA Monitor
Thu Jul 09, 2015 9:19 pm
pluggy wrote: The problem with Gert's board is that you need to sacrifice the all the GPIO to use it. The GPIO is arguably the most useful part of the Pi.
I agree...that's arguable.
Or your local thrift/secondhand shop, friends, neighbors, garage sales, businesses that are replacing older systems. It may take a little time and some running around, but there's a lot of DVI-capable monitors out there. Also...don't forget to actually check the monitor you have. It might have a DVI connector you never noticed or used (sometimes they're in awkward places).
metalj
Re: VGA Monitor
Thu Jul 09, 2015 10:47 pm
I'm using the piview and it works perfectly. Plug and play. I haven't read much about gerts adapter aside from it technically works. Also it probably wouldn't fit in some cases/enclosures. Using gerts adapter probably requires a setup piview again plug and play.
Backspace 28 times :)
Kevin2341
Re: VGA Monitor
Thu Jul 09, 2015 10:55 pm
Save yourself $10 and just VNC. If you're directly linked you won't see any lag at all that is noticeable to you. All you need to do is find the IP, then SSH in, download any necessary software to do so, set up a session, and start a client on your PC. Then you have complete access to your Pi remotely all on one keyboard, mouse and monitor(s).
BMS Doug
Re: VGA Monitor
Fri Jul 10, 2015 6:56 am
metalj wrote:I'm using the piview and it works perfectly. Plug and play. I haven't read much about gerts adapter aside from it technically works. Also it probably wouldn't fit in some cases/enclosures. Using gerts adapter probably requires a setup piview again plug and play.
Yes, the Gert-VGA does require setup.
Doug.
Can
Re: VGA Monitor
Fri Jul 10, 2015 3:31 pm
I live in Turkey , its not costs with cargo : 30$ .And it costs TRY on 100~. Another way
I buy VGA 666
