dhruvvyas90
Problems with 2 USB Cameras and Rpi 2
Tue Jun 30, 2015 12:14 pm
I'm running a Ubuntu 14.04 LTS on my RPi 2. I've OpenCV 2.4.9 installed on it. While running a simple camera capture program works fine.
Here is a code for it.
import numpy as np
import cv2
from time import time
cap = cv2.VideoCapture(0)
cap2 = cv2.VideoCapture(1)
frame_count = 0
while(True):
    # Capture frame-by-frame
    start_t = time()
    ret, frame = cap.read()
    #ret2, frame2 = cap2.read()
    end_t = time()
    time_diff = (end_t - start_t)
    print 'Diff is : %f ms\n' % (time_diff * 1000)
cap.release()
cap2.release()
cv2.destroyAllWindows()
But if I remove comments from the line
to enable getting feeds from the other camera, it takes a lot of time to capture a frame (10 sec or something). Has anyone faced similar problem ? I tested the same program on my ubuntu 15.04 laptop. It works fine on my laptop.
Additional info :
Output of lsusb.
Bus 001 Device 006: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 001 Device 005: ID 046d:082b Logitech, Inc.
Bus 001 Device 004: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Output of dmesg | tail
[email protected]:~/opencv-exp$ dmesg | tail
[  232.894415] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[  236.346374] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[  245.562299] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 1421.092574] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 1448.449098] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 1797.956648] uvcvideo: Non-zero status (-5) in status completion handler.
[ 2117.334545] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 2121.682477] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 2138.670181] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
[ 2369.394190] usb 1-1.2: reset high-speed USB device number 4 using dwc_otg
Update :
While forcing webcam resolutions to 320x240 by
cap.set(3, 320);
cap.set(4, 240);
cap2.set(3, 320);
cap2.set(4, 240);
It works fine. Does it have anything to do with v4l2 or something ?
