joker31
Pi Capabilities: is this possible?
Tue Jun 30, 2015 11:59 am
I need to make a device that is very portable that can take SD card and Copy all the files to another in a short amount of time. I do tons of Video and use Micro SD alot because of the portability. Can I make a Pi based product that will take an SD or USB drive and copy it to a Portable SSD? I dont mind having or not having a display. I would like to have a button to push to start and a LED or LCD that can tell me when its done. I figured there should be a product for it already but i havent seen one. Just trying to see if its possible before getting too far in.
mikronauts
Re: Pi Capabilities: is this possible?
Tue Jun 30, 2015 1:18 pm
You can do it if you use a USB card reader, you cannot remove the Pi's SD boot drive.
You will be limited to at most 15MB/sec copying speed due to the nature of the USB interface on the Pi/
At best, you will be able to copy a 33GB card in about 16 minutes, however it could be a lot longer.
See
http://www.mikronauts.com/raspberry-pi/ ... ter-tests/
for an explanation of the USB bandwidth limitation.
joker31 wrote:I need to make a device that is very portable that can take SD card and Copy all the files to another in a short amount of time. I do tons of Video and use Micro SD alot because of the portability. Can I make a Pi based product that will take an SD or USB drive and copy it to a Portable SSD? I dont mind having or not having a display. I would like to have a button to push to start and a LED or LCD that can tell me when its done. I figured there should be a product for it already but i havent seen one. Just trying to see if its possible before getting too far in.
PiGraham
Tue Jun 30, 2015 1:35 pm
Some devices here
http://www.bhphotovideo.com/c/buy/Stand ... 4000227848
A cheap tablet or smartphone (SD with slot) and a USB disk might be an option (watch out for OTG /USB host support though. Some cheap tablets won't talk to USB storage..
Pi can certainly do it, with USB/SATA adaptor, USB SD adaptor, battery pack and a case.
You could detect the insertion of the SD card an automatically start a copy to USB HD. Flash an LED until the copy is done then automatically un-mount the drives for safe removal. Could all be done with BASH script.
One of the 'UPS' boards that let the Pi turn off it's power would be a good idea, so that it can just shut down once the copy is done.
Model 2B for the USB ports or Model A+ for size and lower power and use a card reader with built-in hub.
Massi
Tue Jun 30, 2015 1:39 pm
mikronauts wrote:You will be limited to at most 15MB/sec copying speed due to the nature of the USB interface on the Pi/
considering that the source will be usb, and the target will be usb again, i'd say.. half of this :)
i don't think the pi can be a good choice for this task. It can obviously do what you want, but the 2.0 usb bus is a big bottleneck..
