btuning1001
small ethernet problem
Thu Jun 25, 2015 5:14 pm
After conventional installation Raspbian with noobs v 1.4 to raspberry PI 2 . How can I configure my internet connection on raspberry for me to download apt. (my ethernet cable is connected directly to an Ethernet switch (I'm at university)) attached my configuration of my PC for internet connection.
http://i.imgur.com/buDYOEB.jpg
Thank you very much,
drgeoff
Re: small ethernet problem
Thu Jun 25, 2015 6:22 pm
Google for configuring a RPi with a static IP address. Use the same IP numbers that you see on your PC. Do not try to have both your PC and RPi connected to the network at the same time.
B.Goode
Thu Jun 25, 2015 6:28 pm
btuning1001 wrote: How can I configure my internet connection on raspberry for me to download apt. (my ethernet cable is connected directly to an Ethernet switch (I'm at university))
Ask the IT Help Desk or Network Support team at your University for advice. (College and University networks often have technically-enforced restrictions on what devices can be connected to their networks.)
betruk
Fri Jun 26, 2015 6:30 am
drgeoff wrote:Google for configuring a RPi with a static IP address. Use the same IP numbers that you see on your PC. Do not try to have both your PC and RPi connected to the network at the same time.
Wow, brilliant. This works for me, thank you.
btuning1001
Fri Jun 26, 2015 7:32 am
you can give me configuration for raspberry with configuration for my PC. thnks
