trlaing
Raspberry Pi 2 - Move MySQL database to USB stick
Wed Jun 17, 2015 12:07 pm
Hello!
I am having a mess around with installing different things on my Raspberry Pi 2. My latest project is installing a MySQL server on it. I have this working fine, but once I implement the MySQL server for the purpose I will use it for, the database will be rather large. Therefore, I would like to move the MySQL data files onto my Sandisk Cruzer Blade 64GB USB stick formatted to ext4. I have followed the following guide to do it:
http://gagsap37.blogspot.co.uk/2014/11/ ... -data.html
However, after copying the data folder to the USB drive and changing the datadir in the /etc/mysql/my.cnf file, I get the following message when trying to restart the MySQL server:
[FAIL] Starting MySQL database server: mysqld . . . . . . . . . . . . . . failed!
I have changed the permissions to pretty relaxed ones (and probably unsafe), so I don't think it has to do with permissions:
pi@raspberrypi /mnt/disk1/mysql $ ls -lrt
total 28692
-rw-rw-rw- 1 root root        0 Jun 16 23:27 debian-5.5.flag
-rw-rw-rw- 1 root root 18874368 Jun 16 23:27 ibdata1
-rw-rw-rw- 1 root root  5242880 Jun 16 23:27 ib_logfile1
-rw-rw-rw- 1 root root        6 Jun 16 23:27 mysql_upgrade_info
drwxrwxrwx 2 root root     4096 Jun 16 23:27 mysql
drwxrwxrwx 2 root root     4096 Jun 16 23:27 performance_schema
drwxrwxrwx 2 root root     4096 Jun 16 23:27 testdb
drwxrwxrwx 2 root root     4096 Jun 16 23:27 phpmyadmin
-rw-rw-rw- 1 root root  5242880 Jun 17 12:48 ib_logfile0
When I change the datadir back to the default, the MySQL server starts fine.
Any help would be greatly appreciated!
trlaing
Re: Raspberry Pi 2 - Move MySQL database to USB stick
Wed Jun 17, 2015 12:38 pm
I think I have resolved this myself. I stopped the server and ran the following command:
chown -R mysql:mysql /newlocation/mysql
Then it started fine :-)
trlaing
Wed Jun 17, 2015 1:37 pm
Okay, so here is my attempt at an idiot's guide to moving your MySQL data folder to a USB drive. I have presumed a couple of things:
1. There is only one USB drive plugged into the Raspberry Pi. When plugged in, it is found at /dev/sda1 (mine always has been).
2. You want to format the USB drive to ext4 file system.
First of all, plug in the USB drive. We want to format it to ext4 file system:
sudo mkfs.ext4 /dev/sda1 -L usbdrive
Now we want to auto-mount the USB drive. We need to edit the /etc/fstab file:
sudo nano /etc/fstab
Add the following line to the bottom:
/dev/sda1       /mnt/disk1      ext4    defaults        0       0
Now we need to test that the auto-mount works:
sudo mount -a
Now go to the folder we have mounted it to see if it has worked:
mount
And you should see the line at the bottom saying something like:
/dev/sda1 on /mnt/disk1 type ext4 (rw,relatime,data=ordered)
Now to move the MySQL data folder to the USB drive. First we need to stop the MySQL server:
sudo service mysql stop
Then navigate to the folder where we would like to put the MySQL data folder:
cd /mnt/disk1
Create the folder for the data files:
sudo mkdir mysql
Now to copy the data files. We need to do this as a superuser to access the data folder:
sudo su
Now the prompt will look different:
root@raspberrypi:/mnt/disk1#
Enter the following to copy the files:
cp –Rv /var/lib/mysql/* /mnt/disk1/mysql/
Change the ownership of the folder so MySQL can access it:
chown -R mysql:mysql /mnt/disk1/mysql
And exit superuser mode:
exit
Now we're back to the usual prompt:
pi@raspberrypi /mnt/disk1 $
Now we must edit the MySQL configuration to let it know where the new data folder is:
sudo nano /etc/mysql/my.cnf
Change the line:
datadir                = /var/lib/mysql
to:
datadir                = /mnt/disk1/mysql
Now restart the MySQL server:
sudo service mysql start
Hopefully you will see a message like the following:
[ ok ] Stopping MySQL database server: mysqld.
[ ok ] Starting MySQL database server: mysqld . ..
[info] Checking for tables which need an upgrade, are corrupt or were
not closed cleanly..
If not, then my first attempt at an idiot's guide isn't very good!
dharashah
Mon Jul 18, 2016 7:41 am
Hi trlaing,
Thanks for a very descriptive guide.
I am getting some issues
I have used home
cp: cannot stat ‘–Rv’: No such file or directory
cp: omitting directory ‘/var/lib/mysql/embroidery’
cp: omitting directory ‘/var/lib/mysql/mysql’
cp: omitting directory ‘/var/lib/mysql/performance_schema’
cp: omitting directory ‘/var/lib/mysql/phpmyadmin’
embroidery is the database i need. And somehow these folders are getting ommitted
When I tried starting MYSQL, I got error
Job for mysql.service failed. See 'systemctl status mysql.service' and 'journalctl -xn' for details.
I will appreciate any help
trlaing
Mon Jul 18, 2016 7:55 am
I have no idea why you get the error
I tried the command myself and it does not give the same error. If you are copy and pasting it might be picking up some unwanted characters. If you type in the code to make sure there are no extra characters...
dharashah
Mon Jul 18, 2016 8:15 am
Ok. I changed the command
to
cp –r /var/lib/mysql/* /mnt/disk1/mysql/
This removed the error
And also solved the problem on ommission of folders
And then everything started working!!!!
:D
danman800
Tue Sep 06, 2016 3:38 am
Hi wouldnt it be better to move the folder and then create a symbolic link to it in its original location? Then you wont need to configure any changes in the config files...
Am i wrong?
trlaing
Tue Sep 06, 2016 5:59 am
Your could try it and see if it works. Please post your result here so others can benefit from it.
mfa298
Wed Sep 07, 2016 9:18 am
A couple of comments that might improve the tutorial:
Rather than 'sudo su' in the middle you could run 'sudo -i' (which does the equivalent thing) at the start and save the need for sudo all the time. Alternately you could just sudo for the couple of commands between the sudo su and exit.
Having labelled the ext4 partition when you formatted it (the -L usbdrive option to mkfs.ext4) you can use that label when mounting it by using LABEL="usbdrive" in /etc/fstab instead of the device (/dev/sda1) this means that if another drive is plugged in the mount will still work correctly. There's also a UUID option that uses the partitions uuid to mount.
if you added the -p flag to cp it should preserve the permissions so you don't need to chown/chmod everything afterwards.
chown mysql: /mnt/disk1/mysql
cp –rvp /var/lib/mysql/* /mnt/disk1/mysql/
You'll still need to chown the root mysql folder but that can be done after creating it (before the copy) it and doesn't need to be recursive.
After getting the new location working I'd move the old DB out from /var/lib/mysql otherwise you might get confused data if the config reverts for some reason.
sudo mv /var/lib/mysql{,.old}
(the {,.old} is a shell expansion so get's expanded to: '/var/lib/mysql /var/lib/mysql.old')
As someone else suggested rather than changing the datadir option it my.cnf you could use a symlink
sudo ln -s /mnt/disk1/mysql /var/lib/mysql
(NB: this assumes you did the mv above)
A better option might be a bind mount (manual method)
sudo mkdir /var/lib/mysql
sudo chown mysql: /var/lib/mysql
sudo mount --bind /mnt/disk1/mysql /var/lib/mysql
To make this automatic enter the following into /etc/fstab and use mount -a (you'll still need to have done the mv, mkdir and chown steps above before it can mount safely the first time)
/mnt/disk1/mysql    /var/lib/mysql                 none    bind    0 0
(I've used the bind mount setup on some big production DB's in the past without issue)
samarkh
Fri Mar 17, 2017 11:27 am
I too had this problem, and its due to the
being changed to
a dash being changed to an endash or emdash
I found it on this site http://askubuntu.com/questions/578337/cp-cannot-stat-r
dharashah wrote:Ok. I changed the command
to
:D
