gkreidl
Re: Raspi and YouTube
Wed Jul 15, 2015 4:40 am
emeyeraway wrote:I tried that already. The fact is, when I run a Scratch program, the sound works just fine (through the audio jack connected to a stereo set). Why shouldn't it work for YouTube videos?
omxplayer(GUI) doesn't care about the audio mixer settings, because it accesses the audio hardware directly. I suppose your system (in config.txt) is set to enable HDMI audio.
omxplayer can be told to use the audio jacks with the following option:
-o local
omxplayerGUI can be set to use those options.Open the settings page in kweb. Scroll down to "omxoptions". Enter
-o
local
and click "save"
Do the the same in the area below, called "omxaudiooptions" and also in the next field, "omx_livetv_options"-
Scroll down to "youtube_omxoptions" and do the same.
The default settings are overwritten, when kweb is updated. So it's a good idea to save your settings as a preset:
Enter a name, e. g. "audiojack" and click "save preset".
Check the omxplayerGUI manual for more details.
Minimal Kiosk Browser (kweb)
emeyeraway
Thu Jul 16, 2015 6:41 am
My audio started working suddenly without any input from me, and it worked until I shut down. Next time I tried it didn't work any more. So I thought I'd try reloading Minimal Kiosk Browser. I deleted it, then went back to:
wget http://steinerdatenbank.de/software/kweb-1.6.5.tar.gz
tar -xzf kweb-1.6.5.tar.gz
cd kweb-1.6.5
./debinstall
When it finished, it said all important programs had been found, and that I could start using MKB after I install it. I tried "sudo apt-get install kweb_1.6.5-1_armhf.deb", but that didn't work. What is the final step? How do I install once all the files are available?
gkreidl
Thu Jul 16, 2015 6:54 am
./debinstall does everything you need. Kweb is already installed.
The message is a bit irritating. In the past the script was run before installation, now it's run after installation, I'll change the text in the next version.
emeyeraway
Thu Jul 16, 2015 10:20 am
But it's NOT! When I go to "Internet" in the "Menu" at the top left of the screen, neither Minimal Kiosk Browser icon is there, so I have nothing to click on. That's how I used to go to MKB. Now I'm stumped!
gkreidl
Thu Jul 16, 2015 10:45 am
emeyeraway wrote:But it's NOT! When I go to "Internet" in the "Menu" at the top left of the screen, neither Minimal Kiosk Browser icon is there, so I have nothing to click on. That's how I used to go to MKB. Now I'm stumped!
I have no idea. Try running ,/debinstall again.
You cannot install it with apt-get.
emeyeraway
Thu Jul 16, 2015 7:03 pm
I've tried unsuccessfully 3 times to install MKB. But I did notice that when I boot up my RasPi, I get the following warning:
"Kernel lacks cgroups or memory controller not available, not starting cgroups. ...warning"
Could this be the problem?
emeyeraway
Thu Jul 16, 2015 7:36 pm
...or is it possible that I somehow deleted the MKB icon permanently, and the software is actually installed, but I can't see it?
gkreidl
Thu Jul 16, 2015 8:11 pm
emeyeraway wrote:I've tried unsuccessfully 3 times to install MKB. But I did notice that when I boot up my RasPi, I get the following warning:
No. this is normal.
ThomasS
Thu Jul 16, 2015 8:12 pm
I'd try Chromium with pepperflash. Works fine for me.
ThomasS
gkreidl
Thu Jul 16, 2015 8:13 pm
emeyeraway wrote:...or is it possible that I somehow deleted the MKB icon permanently, and the software is actually installed, but I can't see it?
you can simply test that. Run from a terminal
kweb
or
kweb3
and also try
omxplayergui.py
gkreidl
Thu Jul 16, 2015 8:15 pm
ThomasS wrote:I'd try Chromium with pepperflash. Works fine for me.
To play youtube video?
emeyeraway
Thu Jul 16, 2015 10:37 pm
gkriedl, YOU DA MAN!!
What I mean is, yes, MKB is still there, and as soon as I entered kweb from the terminal window, it jumped to the page with the youtube option. However, there was still no sound when I chose a video and clicked on play. So I went back to the instructions you had sent regarding -o and local, and after making all those changes (and saving them as "audiojack", as you suggested), I now have both great video AND great sound.
You have the makings of a great teacher: (1) Competence and (2) Patience. Thank you for hanging in there with me until the problem was solved.
Return to “Beginners”
