yenyu88
How to read data from USB input
Sat Jun 06, 2015 5:05 am
Hi guys,
Currently I'm doing my final year project with the use of Raspberry Pi.
Concept: Energy Monitoring using Raspberry Pi.
I've bought myself a Raspberry Pi and a Energy Monitoring Set. Since the Energy monitoring has a USB output to connect to a computer, but rather to save cost in a long run, I'm connecting it to a Raspberry Pi which is using a different OS platform. Thus I'm enquiring on how am I able to read out the data and store it in a file and finally graph it out into charts/graph in terms of 1-Hour, 6-Hours, 24-hours and even a week usage.
I've setup my basic Raspberry Pi, and tried googling about this topic but it isn't that clear, and would like to seek insight on this function with the use of python language.
Thanks all for the insight in advance.
Regards,
Newbie Raspberry Pi User,
Yen Yu
yenyu88
Re: How to read data from USB input
Thu Jun 11, 2015 2:23 am
Any experts can help out? :)
ame
Thu Jun 11, 2015 2:25 am
What is the energy monitoring USB device?
Can you plug it in and print the result of
lsusb
betruk
Thu Jun 11, 2015 6:44 am
Same problem at my side, any solution?
ame
Thu Jun 11, 2015 6:46 am
betruk wrote:Same problem at my side, any solution?
Same suggestion.
What is the USB vendor ID and product ID?
rpdom
Thu Jun 11, 2015 8:14 am
As ame says, first step is to identify the device. Use "lsusb" (That's lower-case "LSUSB", not "1SUSB").
Then find out if there are suitable drivers for it.
Then look for any documentation on how to communicate with it.
yenyu88
Sat Jul 04, 2015 4:09 am
Hello guys,
Sorry for the long late reply cos my equipment got faulty and waited for a 2 week replacement. I got my equipment yesterday. I've keyed in lsusb, and it shows as follows
Bus 001 Device 004: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port.
Do you guys means to google the above product ID and documentation and look for the communication method?
But how do i implement it in python to allow my raspberry to continuously pulling data from it?
Regards,
Yen Yu
Sat Jul 04, 2015 4:41 am
This is a little out of date but may give some pointers:
http://raspberrypi.stackexchange.com/qu ... ial-device
Thinking outside the box is better than burying your head in the sand...
Sat Jul 04, 2015 4:47 am
A pl2303 should be recognised and auto identified as /dev/ttySx - the dmesg command will tell you what tty device it is.
ame
Sat Jul 04, 2015 4:56 am
Ok, so it's just a serial port. You don't need anything special, just open the port and you can send and receive data.
yenyu88
Sun Jul 05, 2015 4:43 pm
Alright, I understand. But how am I able to open the port and read specific data from the port using Pyhton source code?
Because my project requires the reading of Power (Watt/kwH) measurement from time to time. Thus i believe within python code, there must be a line for the raspberry pi to prompt or pull the data. (E.g. probing every 1min or so).
B.Goode
Sun Jul 05, 2015 6:16 pm
yenyu88 wrote:how am I able to open the port and read specific data from the port using Pyhton source code?
One way is to install and use the python-serial module.
It can be installed via:
sudo apt-get install python-serial
The documentation, including example code, is here: pyserial.sourceforge.net
mikronauts
Sun Jul 05, 2015 8:06 pm
You need the documentation for your "Energy Monitoring Set", specifically, how it sends the readings via the usb serial port.
yenyu88 wrote:Hi guys,
Regards,
Yen Yu
http://Mikronauts.com - home of EZasPi, RoboPi, Pi Rtc Dio and Pi Jumper @Mikronauts on Twitter
Advanced Robotics, I/O expansion and prototyping boards for the Raspberry Pi
texy
Mon Jul 06, 2015 11:18 am
FYI, the
is a very common standard usb-to-serial chip. It doesn't tell you what hardware you are connecting.
If you can give and google the actual make and model number of the
then you may be able to see if this has been done before and follow that example.
Texy
yenyu88
Wed Jul 08, 2015 6:21 am
Hi Guys,
I've did a few search. I manage to find the manual, but it doesn't say about how the USB to Serial communicates.
https://cdn.shopify.com/s/files/1/0510/ ... uction.pdf
texy
Wed Jul 08, 2015 6:29 am
Then you need to ask the manufacturer, or think of a new project!
Texy
ame
Wed Jul 08, 2015 6:31 am
On page 28 they ask you to download the software from their website. That's probably not going to help you. Instead, you could email the company and ask them for details about the protocol. If that doesn't work you'll need to be a detective.
The first thing you need to know is the baud rate of the device. Try something popular like 4800, 9600 or 115k (or just try all of them until you get something sensible). It is possible that the unit will send data out periodically, so you just have to capture that data and look at it. Or maybe you are supposed to send a command to the unit to get some data out. Unfortunately, without the protocol details you are in the dark.
You could also download their software and run it on another PC, then hook something up (maybe hardware, maybe software) to capture the data going between their software and the unit, and examine it later to figure out the protocol.
Return to “Beginners”
