pangren
Power Required for Raspberry Pi2
Fri Jun 05, 2015 6:50 am
Hi, I have owned a Raspberry pi model B before and I want to upgrade to a Pi 2. I just want to know if I can run it without using a powered usb hub.
My power requirements are just a WiFi Dongle, and a portable 2.5" HDD. Usage, wise, basically I'll be running openelec and playing movies from the HDD.
Re: Power Required for Raspberry Pi2
Fri Jun 05, 2015 7:22 am
pangren wrote:Hi, I have owned a Raspberry pi model B before and I want to upgrade to a Pi 2. I just want to know if I can run it without using a powered usb hub.
You will need a decent good quality PSU 5V2A and increase the USB amps to ditch the HUB.
This applies to B+ & 2B
https://projects.drogon.net/testing-set ... berry-pi-b
http://swag.raspberrypi.org/collections ... wer-supply
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
Return to “Beginners”
