Is this the correct way to install noobs?
Posted: Thu May 28, 2015 12:54 am
by abefroman99
Disk /dev/sdc: 30.9 GB, 30908350464 bytes
32 heads, 32 sectors/track, 58953 cylinders, total 60367872 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
   Device Boot      Start         End      Blocks   Id  System
/dev/sdc1            2048    60367871    30182912    b  W95 FAT32
$ unzip NOOBS_v1_4_1.zip
Archive:  NOOBS_v1_4_1.zip
  inflating: bootcode.bin
  inflating: BUILD-DATA
   creating: defaults/
   creating: defaults/slides/
  inflating: defaults/slides/A.png
  inflating: INSTRUCTIONS-README.txt
   creating: os/
   creating: os/Raspbian/
  inflating: os/Raspbian/flavours.json
  inflating: os/Raspbian/release_notes.txt
  inflating: os/Raspbian/os.json
  inflating: os/Raspbian/boot.tar.xz
   creating: os/Raspbian/slides_vga/
  inflating: os/Raspbian/slides_vga/B.png
  inflating: os/Raspbian/slides_vga/G.png
  inflating: os/Raspbian/slides_vga/D.png
  inflating: os/Raspbian/slides_vga/E.png
  inflating: os/Raspbian/slides_vga/F.png
  inflating: os/Raspbian/slides_vga/C.png
  inflating: os/Raspbian/slides_vga/A.png
  inflating: os/Raspbian/root.tar.xz
 extracting: os/Raspbian/Raspbian_-_Boot_to_Scratch.png
 extracting: os/Raspbian/Raspbian.png
  inflating: os/Raspbian/partitions.json
  inflating: os/Raspbian/partition_setup.sh
   creating: os/Data_Partition/
  inflating: os/Data_Partition/os.json
 extracting: os/Data_Partition/Data_Partition.png
  inflating: os/Data_Partition/partitions.json
 extracting: os/Data_Partition/data.tar.xz
  inflating: recovery7.img
 extracting: recovery.cmdline
  inflating: recovery.elf
 extracting: RECOVERY_FILES_DO_NOT_EDIT
  inflating: recovery.img
  inflating: recovery.rfs
  inflating: riscos-boot.bin
desktop:~/Downloads/noobs$ sudo mkdir /pi
desktop:~/Downloads/noobs$ sudo mount /dev/sdc1 /pi
desktop:~/Downloads/noobs$ ll
total 784452
drwxrwxr-x 4 abraham abraham      4096 May 27 19:48 ./
drwxr-xr-x 8 abraham abraham    36864 May 27 19:48 ../
-rw-r--r-- 1 abraham abraham    17856 Feb 18 16:26 bootcode.bin
-rw-rw-r-- 1 abraham abraham     356 May 11 15:53 BUILD-DATA
drwxrwxr-x 3 abraham abraham    4096 Feb 17 12:45 defaults/
-rw-rw-r-- 1 abraham abraham      2250 Feb 18 16:23 INSTRUCTIONS-README.txt
-rw-rw-r-- 1 abraham abraham 778132405 May 27 19:47 NOOBS_v1_4_1.zip
drwxrwxr-x 4 abraham abraham    4096 Feb 17 14:14 os/
-rwxrwxr-x 1 abraham abraham   2148120 Feb 18 16:24 recovery7.img*
-rw-r--r-- 1 abraham abraham        54 Feb 18 16:26 recovery.cmdline
-rw-r--r-- 1 abraham abraham   554520 Feb 18 16:26 recovery.elf
-rw-rw-r-- 1 abraham abraham         0 Feb 18 16:26 RECOVERY_FILES_DO_NOT_EDIT
-rwxrwxr-x 1 abraham abraham  2100464 Feb 18 16:26 recovery.img*
-rw-rw-r-- 1 abraham abraham  20238331 Feb 18 16:26 recovery.rfs
-rw-rw-r-- 1 abraham abraham     9728 Feb 18 16:23 riscos-boot.bin
desktop:~/Downloads/noobs$ mv * /pi/
$ ls /pi/
bootcode.bin  defaults                 NOOBS_v1_4_1.zip  recovery7.img     recovery.elf                recovery.img  riscos-boot.bin
BUILD-DATA    INSTRUCTIONS-README.txt  os                recovery.cmdline  RECOVERY_FILES_DO_NOT_EDIT  recovery.rfs
Re: Is this the correct way to install noobs?
Posted: Thu May 28, 2015 6:36 am
by metalj
https://www.raspberrypi.org/help/noobs-setup/
This is how I did it. Welcome sausage king of Chicago. ;)
Posted: Thu May 28, 2015 6:38 am
by rpdom
That should work except for the fact that you've also copied the zipfile onto the card, which will probably mess things up.
Try it this way instead
(assuming clean formatted filesystem on card)
desktop:~/Downloads/noobs$ unzip NOOBS_v1_4_1.zip -d /pi
(unzipping happens)
desktop:~/Downloads/noobs$ sudo umount /dev/sdc1
Which saves you a step by unzipping the contents directly onto the SD card
