Massi
433MHz receiver antenna
Mon May 25, 2015 8:18 am
This is going into "beginners" since i suspect my question will have a very stupid answer :)
Just to see if there's a big difference from "cheap chinese receiver" and superheterodyne receiver, i bought this from DX
http://www.dx.com/p/315-mhz-433-92-mhz- ... WLYhtLtlYQ
(Obviously i already got one of these some months ago http://www.dx.com/p/433mhz-rf-transmitt ... WLZttLtlYQ )
Now, as you can see the new module has a group of 3 pins that are gnd, 5V and data. This is not a problem even for me :)
But why the hell there is another couple of pins for antenna?? i always connected only ONE wire as antenna to 433MHz receivers (and transmitters), why is this asking for a ground too?
beta-tester
Re: 433MHz receiver antenna
Mon May 25, 2015 9:47 am
Massi wrote:...But why the hell there is another couple of pins for antenna?? i always connected only ONE wire as antenna to 433MHz receivers (and transmitters), why is this asking for a ground too?
maybe for those, who wants to connect a coax cable instead of a wire-antenna directly, or if it is used in a sockes, to have the ground trace close to the antenna pin...
and those people were crying... so they populated an extra pin for (shileding-)ground close to the antenna output - so they do not have to "drill" their own ground point.
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
louarnold
Mon May 25, 2015 2:37 pm
Ach...the pin is there so you can connect a big heavy wire between it and a nail that goes into the ground. I see it in all the antenna mounting pics. It extends the range immensely.
(Just joking...don't do it!)
