Writing rights?
Posted: Sat May 23, 2015 6:50 am
by Krassegrand
I have an external HDD for watching videos but now I want to move 1 file from the Raspberry to the HDD but I don't seem to have writing permission on it. How do I fix that?
Jörgen
Edit
I have tried with another USB-stick but no difference.
Re: Writing rights?
Posted: Sat May 23, 2015 9:58 am
by Krassegrand
I tryed with
sudo su
from http://www.raspberry-projects.com/pi/co ... privileges
but no help.
Jörgen
Re: Writing rights?
Posted: Sat May 23, 2015 11:13 am
by DougieLawson
what does a
mount
command show?
The ownership and masked permissions control who can write to a mounted USB stick with a FAT filesystem.
Re: Writing rights?
Posted: Sat May 23, 2015 1:15 pm
by Krassegrand
Here is the mount command!
pi@raspberrypi ~ $ mount
/dev/root on / type ext4 (rw,noatime,data=ordered)
devtmpfs on /dev type devtmpfs (rw,relatime,size=470416k,nr_inodes=117604,mode=755)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=94944k,mode=755)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /run/shm type tmpfs (rw,nosuid,nodev,noexec,relatime,size=189880k)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
/dev/mmcblk0p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro)
/dev/sda1 on /media/Elements type ntfs (ro,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0177,dmask=077,nls=utf8,errors=continue,mft_zone_multiplier=1,uhelper=udisks)
pi@raspberrypi ~ $
Jörgen
Re: Writing rights?
Posted: Sat May 23, 2015 1:32 pm
by DougieLawson
Krassegrand wrote: /dev/sda1 on /media/Elements type ntfs (ro,nosuid,nodev,relatime,uid=1000,gid=1000,fmask=0177,dmask=077,nls=utf8,errors=continue,mft_zone_multiplier=1,uhelper=udisks)
There's your problem. Your filesystem is read-only.
Have you got ntfs-3g installed?
Re: Writing rights?
Posted: Sat May 23, 2015 2:56 pm
by Krassegrand
How do I check and how do I install?
Jörgen
Re: Writing rights?
Posted: Sat May 23, 2015 3:19 pm
by Krassegrand
I found this!
viewtopic.php?t=16803&p=219070
Edit
and it works!
Thanks!
:D
Re: Writing rights?
Posted: Sat May 23, 2015 3:29 pm
by rpdom
Yes, that's the way to do it :)
