JavaScript
Posted: Sat May 23, 2015 5:30 am
by Krassegrand
I am trying to watch a TV channel but I get the message
"To watch this program You need to enable JavaScript. Find out how.
If I recall right from earlier there is something else then Java for Linux, am I right?
Jörgen
Re: JavaScript
Posted: Sat May 23, 2015 5:36 am
by joan
JavaScript is not Java. Your browser should have an option to allow JavaScript programs to run. Which browser are you using?
Re: JavaScript
Posted: Sat May 23, 2015 5:55 am
by Krassegrand
Ok!
How is it done in Kiosk for Raspbian?
Jörgen
Re: JavaScript
Posted: Sat May 23, 2015 6:05 am
by gkreidl
Krassegrand wrote:Ok!
Jörgen
There's an icon in the toolbar to switch JavaScript on and off.
You can also configure kweb(3) to enable it when it starts.
Re: JavaScript
Posted: Sat May 23, 2015 6:13 am
by Krassegrand
I have chosen Configuration in the tool bar and enabled javaScript but I still get the same message! (To watch this program You need to enable JavaScript. Find out how.)
gkreidl wrote:You can also configure kweb(3) to enable it when it starts.
kweb(3)?
Is that done in the terminal?
It would be nice to have it starting by it self.
Jörgen
Re: JavaScript
Posted: Sat May 23, 2015 6:16 am
by gkreidl
Krassegrand wrote:I have chosen Configuration in the tool bar and enabled javaScript but I still get the same message! (To watch this program You need to enable JavaScript. Find out how.)
kweb(3)?
Jörgen
No. On the configuration page (or with command line arguments if starting from a script, for example).
Re: JavaScript
Posted: Sat May 23, 2015 6:23 am
by Krassegrand
Sorry!
I saw the JavaScript button now!
It was to simple for me to understand!
Thank You!
Now I just need to get the VPN working!
Jörgen
Re: JavaScript
Posted: Sat May 23, 2015 6:38 am
by Krassegrand
By the way, I still cant work out how to use the bookmarks in Kiosk!
Jörgen
Re: JavaScript
Posted: Sat May 23, 2015 7:00 am
by gkreidl
Krassegrand wrote:By the way, I still cant work out how to use the bookmarks in Kiosk!
Jörgen
Manual, page 25.
Re: JavaScript
Posted: Sat May 23, 2015 9:08 am
by Krassegrand
gkreidl wrote:Krassegrand wrote:By the way, I still cant work out how to use the bookmarks in Kiosk!
Jörgen
Manual, page 25.
Thank You!
