hi
how can I increase boot and start up speed(reduce time) for raspbian distr??plz I need software or settings solution ??
How was Raspbian installed - via the NOOBS installer or from an "image" (*.img) file?hamza wrote:hi
Good points - I tend to forget about things like the "boot to desktop option", mainly because, since my monitor is shared between Pi(s) and my netbook, they're running headless and thus "booted" when green led ACTivity subsides and I can login via SSH. (By then the wired network is up too). NOOBS, of course, introduces quite a long "boot-delay" to allow for keyboard and subsequent 'Shift' key detection to trigger switch into recovery mode before booting the (current) O.S. (Hence the question in my previous post)B.Goode wrote:Some possible ground rules to encourage a like-for-like discussion:
How do you detect when the system is 'Up'? (When you have a shell prompt? When the GUI is displayed? When the network is up?)
Do you have a 'Holy Grail' that you must achieve, or do you just want it 'a bit faster'?
From raspbian image not noobs.
What model of Pi?
Trev.
piCore (TinyCore) is likely the most minimalist and fastest OS, but it will need a steep learning curvehamza wrote:You can use Arch, raspbian-ua-netinstall, minibian or dietpi, which are all slimmed down versions of Raspbian which boot quickly. You also need a quick SD card/quote]
I think its very good solution..but where I Can find them..becouse i did not find them here in download site.
