darkaragon
Project idea from a beginner.
Thu May 07, 2015 8:29 pm
Hello all,
I am thinking of getting into the Raspberry Pi world and as the person I am, I don't like to start small. I learn quicker when I run.
I would like to build 2 RPi's in my car, but both powered on if possible within the same electric circuit. Each having a screen and WiFi of its own. Only the main screen (center dash) would have Bluetooth keyboard/mouse. Screen 2 would be on passenger side, reading my OBDII and log all events (yes, track day car). I have a attached a little paint diagram to make things clearer.
I am aware that there are ready made solutions out there, but not for the price of RPi. Also, we prefer to do everything on the car ourselves.
I would appreciate any suggestions regarding the power supply for this project (and any improvements to the idea).
Regards,
Red
toxibunny
Re: Project idea from a beginner.
Fri May 08, 2015 7:12 am
No need for 2 Pis - you can just attach 2 screens to 1 pi...
note: I may or may not know what I'm talking about...
BMS Doug
Fri May 08, 2015 7:13 am
Your paint drawing didn't attach, maybe the file size was too large, try saving it as a GIF.
this may help with OBDII, adding a separate display should be simple.
Any 5V 5A UBEC will work as a power supply for 2 Pi's.
Doug.
darkaragon
Fri May 08, 2015 11:58 am
toxibunny wrote:No need for 2 Pis - you can just attach 2 screens to 1 pi...
Both screens running separate software at the same time without interference?
kusti8
Fri May 08, 2015 11:59 am
That you cannot do. You can only use a splitter to have the same picture on both screens.
ame
Fri May 08, 2015 12:02 pm
Linux is a multi-user, multi-processing system. If the hardware is powerful enough it can service many users, with a display each, without them interfering with each other.
Maybe you are most familiar with Windows, which actively prevents more than one user using the system at the same time.
Anyway, you could have two displays, and each one is a different Linux device. Just configure your software to output to the desired device and it will work as you expect.
Ignore kusti8.
BMS Doug
Fri May 08, 2015 12:16 pm
Ignore kusti8.
You will need to choose your displays carefully but a Pi 2 could easily output to two screens for your application.
Doug.
kusti8
Fri May 08, 2015 12:30 pm
Ignore kusti8.
"each one is a different Linux device?"
AFAIK you cannot output on both AV and HDMI. There is no DSI and as far as I have seen Gert's VGA666 has the possibilty, but it hasn't been done.
I'm confused. What are you saying?
ragnarjensen
Fri May 08, 2015 4:32 pm
There are a plethora of SPI and USB displays available. Each has its own framebuffer.
I have a lowly RPiBv2 that handles four displays, HDMI + PiTFT + 2xUSB DisplayLink, quite nicely.
There was a thread about multi-display in a mobile home a while ago: viewtopic.php?p=664766
Ragnar
kusti8
Fri May 08, 2015 7:10 pm
Ah...
Forgot about that. :oops:
