sic
How to connect FingerPrint Scanner TTL GT511C3?
Tue May 05, 2015 4:00 pm
I have a Raspberry Pi Model B and I want to use FingerPrint Scanner TTL GT511C3 for a project I am working on. Based from the link, does that mean that I can connect the FingerPrint Scanner Module directly to the Raspberry Pi without the use of any level shifters? Could I just connect the Module directly to pins 8 and 10 without breaking the Raspberry Pi?
joan
Re: How to connect FingerPrint Scanner TTL GT511C3?
Tue May 05, 2015 5:29 pm
It looks ok.
Connect one ends TX to the other ends RX and vice versa.
You need to disable the system's use of the serial link as a login console. If you are using Raspbian there is an option in (sudo) raspi-config to do that.
