cleathy
Commands when starting
Fri Apr 17, 2015 11:43 pm
Hi
I was wondering how can i get my Raspberry Pi to run these commands when starting?
cd C-Berry/SW/fb2cberry
make
sudo mv fb2cberry /usr/local/bin/fb2cberry
sudo fb2cberry &
Thanks (:
MarkHaysHarris777
Re: Commands when starting
Sat Apr 18, 2015 5:52 am
So, without any checks at all, you want your RPi (which model) to compile some source, move it into /usr/local/bin/ and execute it at system startup? Why? Dangerous! ... warning Will Robinson, Danger...
The answer to your question relies on your knowledge of init. The RPi uses 'init' to control system startup. So, you will want to read up on init.d, run levels startup rc0.d rc1.d rc2.d etc, rcS.d , rc.local... and so forth. This is all located in /etc.
Probably you will want to place your startup stuff in rc.local. But, I would never compile sources (make) and without any check whatsoever move that object into /usr/local/bin for execution in the background! That's nuts. So, rethink what you're trying to do, and come up with a better solution.
Cheers,
marcus
marcus
:ugeek:
Sat Apr 18, 2015 9:00 am
cleathy wrote:Hi
make
sudo fb2cberry &
Thanks (:
What possible reason would you have to make and install a new copy of your program every time you boot?
That's normally a one-off operation (until the code changes for some reason).
