Whereis404
Can't write to a file with Python
Fri Apr 17, 2015 7:04 pm
Ill try and get straight to the point.
Here is the code I wrote
# Grabs a line from user input and saves it to a file
import sys
for line in sys.stdin:
	file = open('notes.txt', 'a')
	file.write(line)
	file.close()
I tried running this in a python shell and it worked fine. When I try to run this in terminal, it doesn't work. I have tried using python and python3.
Maybe it is something in my code? I haven't used python before, though I have coded for a while using Java/C++
MarkHaysHarris777
Re: Can't write to a file with Python
Sat Apr 18, 2015 6:17 am
I don't think you want a close() on every write do you??
By running 'in a terminal' do you mean running the python code as a script from the command line?
Where is your shabang line?
#!/usr/bin/python
... rest of script
You need a shabang line to tell sh or bash or whatever how to run the python interpreter.
Check here:
http://www.python-course.eu/python3_execute_script.php
There are lots of ways to run a python script; interpreted, compiled, from another python script, from another shell script, so on and on... do some reading. Google is our friend.
marcus
:ugeek:
kusti8
Sat Apr 18, 2015 12:04 pm
What is your error? One thing I notice off the bat is that you should put the full path to the file in your code.
There are 10 types of people: those who understand binary and those who don't.
Return to “Beginners”
