photo-bro
Networking Two PIs without internet or wires
Fri Apr 10, 2015 6:07 pm
Hello!
I am a college student currently in a networking class. My goal right now is to be able to write a Python based chat client between two PIs that uses a networking method that isn't the internet or ethernet. Something along the lines of using a laserpointer and photodiode to shoot pulses of information across a room, or using a speaker to play a sine wave bursts that a microphone would pick up, etc.
I am not terribly familiar with PIs and what accessories are available. Are there any accessories, such as connecting a laser pointer and photodiode that are easy to order?
Thanks!
Jonn
Re: Networking Two PIs without internet or wires
Sat Apr 11, 2015 6:36 am
That sounds interesting. A laser with a bit of fog to make the beam visible would give a showy demonstration. (Remember eye safety!)
The Gerboard helps demonstrate some capabilities of the GPIO pins. At timecode [4:00-4:10] of the video, Gert mentions transmission of character information, but I suppose it may be over a wire. https://www.raspberrypi.org/gertboard-rev2-video/
(and https://www.youtube.com/watch?t=139&v=Dp_PNI9Qo2k )
A couple videos are inspiring and make it look like a breadboard and a little electronics might do the job for the hardware. Since I am not skilled in electronics, I'd refer you to your school's department for advice--I certainly wouldn't want you to risk damaging your RaspberryPi.
How to make infrared sensor in few steps! https://www.youtube.com/watch?v=XsHnvvSzr1M
Homemade laser motion sensor https://www.youtube.com/watch?v=FA2aj33OwMo
(This beginner video was linked on the Gertboard video's Youtube page: https://www.youtube.com/watch?v=q_NvDTZIaS4 )
There is a bold font caution on the GPIO page: https://www.raspberrypi.org/documentati ... /README.md
It also links to http://elinux.org/RPi_Low-level_peripherals
Some of the places to look for things that work or are available are
http://elinux.org/RPi_VerifiedPeripherals (via http://elinux.org/RPi_Hub)
http://www.adafruit.com/products/1560 (specialized IR receiver and handheld remote)
http://www.element14.com/community/search.jspa?q=IR+LED
I have a toy that responds to sounds, Bleep, the Weebot (from several years ago), but the remote control makes sharp loud noises. That's probably for a good signal to noise ratio, but it isn't as human ear-friendly as Star Wars' R2D2. http://www.amazon.com/Sharper-Image-SI5 ... B000KB8IIK
PiGraham
Sat Apr 11, 2015 9:17 am
Ir remote control transmitter and receiver would work.
You could look at 433MHz radio nowire.
Old style analogue modem techniques should work for audio transmission.
A key thing for reliable communication is to modulate a carrier and file at the recurve to only respond to modulations of that carrier frequency.
Blue tooth serial modules can provide simple point to point links accessed as simple serial(tty) ports.
burricios
Sat Apr 11, 2015 9:23 am
If there is no problem of objects between both Pi's, you could just use an IR emitter/receiver pair in order to send messages to each other. It is very inexpensive and should be quite easy to do.
If you want them to be able to communicate even between different rooms, you could use some RF modules. The NRF24L01+ is a very inexpensive transceiver chip with nice capabilities, and I think there are some libraries for it out there.
You could also use bluetooth, buying a couple HC05 modules from DX or Aliexpress should be very cheap, and again there should be a lot of information for them.
toxibunny
Sun Apr 12, 2015 3:46 pm
using two ultrasonic distance sensors would be a novel way to do it - you've got a transmitter and detector in each...
http://www.dx.com/p/hc-sr04-ultrasonic- ... ule-133696
You could do it with webcams, servo motors, and flags. and do automated semaphore.
loudspeakers and mics.speech synthesis and recognition.have the two pis speak to each otherfor hours on end, saying nothing but 'one. one. zero. zero. one. one. one...'
note: I may or may not know what I'm talking about...
PiGraham
Sun Apr 12, 2015 7:34 pm
toxibunny wrote:You could do it with webcams, servo motors, and flags. and do automated semaphore.
:lol:
Excellent idea!
Here's the flag waving part...
http://www.doctormonk.com/2012/07/raspb ... art-2.html
hippy
Sun Apr 12, 2015 7:46 pm
Have a read-up of IrDA. That should be pretty easy to interface to a Pi's UART.
joan
Sun Apr 12, 2015 9:36 pm
:lol:
Excellent idea!
This is flag waving. Skip the first minute. https://www.youtube.com/watch?v=HBFMTbcNLtg
mikerr
Sun Apr 12, 2015 10:26 pm
Use slow morse code ... then us humans can "eavesdrop" :)
Sun Apr 12, 2015 11:56 pm
The best wireless networking method is documented in RFC 1149 https://www.ietf.org/rfc/rfc1149.txt
The funniest part of that was the implementation of it by the Norwegians from the Bergen Linux User's Group.
http://news.bbc.co.uk/1/hi/sci/tech/1321176.stm
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
mahjongg
Mon Apr 13, 2015 12:10 am
Ah, the old pigeon route isn't it? always good for a laugh, and explaining how TCP/IP works.
BMS Doug
Mon Apr 13, 2015 5:51 am
toxibunny wrote:using two ultrasonic distance sensors would be a novel way to do it - you've got a transmitter and detector in each...
this would require some hardware hacking as the HC-SR04 sends a processed reply (time since transmit pin was pulsed) rather than a raw ultasonic signal received pulse.
Doug.
TacticalNinja
Wed Apr 15, 2015 4:05 pm
I don't really get what you mean by "networking", but if you are only referring to being able to send any form of data, or message from one to another, then any of the above suggestions would suffice. All that's left is for you to decide how the message is encoded/modulated, and decoded/demodulated through what ever medium you used.
scotty101
Wed Apr 15, 2015 4:35 pm
Connect a laser pointer to a transistor and drive it on and off using the Raspberry Pi's UART Tx pin.
At the other end use a photodiode, an op amp and some other bits to connect this to the recieve pin of the UART.
If you use a slow enough baud rate (say 2400) I imagine that should work.
