hamza
video and audio not working
Thu Apr 09, 2015 10:56 pm
Hi all
I have rpi 1 b+and 4 pole cable.
but the video and audio output are not working using 3.5 mm jack
what is the correct configration for my rpi 1 b+??
Re: video and audio not working
Thu Apr 09, 2015 11:14 pm
Clearly Google isn't working for you either.
http://www.raspberrypi-spy.co.uk/2014/0 ... ideo-jack/
hamza
Fri Apr 10, 2015 1:10 pm
Thank u
I tested it using multimeter and its similar to the recommended cable also i solded a new cable on the test pads pp24.25 26 with gnd.. but there is no output.....
Are there special configration????plz advice??
drgeoff
Fri Apr 10, 2015 5:12 pm
hamza wrote:Thank u
Is the RPi booting? Read the "NOT BOOTING" sticky.
hamza
Fri Apr 10, 2015 7:32 pm
Yes its working correctly on hdmi .but when i change to 3.5mm jack there is no video or audio output but the green led is blinking normally..
what about /boot/configration.txt ..are there special configration??
Fri Apr 10, 2015 7:34 pm
What's in your /boot/config.txt file?
hamza
Fri Apr 10, 2015 9:12 pm
I have raspbian with the following in config.txt
#hdmi_safe=1
#disable_overscan=1
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
sdtv_mode=2
Fri Apr 10, 2015 9:23 pm
So you've set it up to use an AV connection to a European PAL TV, is that your TV standard?
Is the TV set to use the right AV input?
What happens if you use a
tvservice -c "PAL 16:9"
or
tvservice -c "PAL 4:3"
command?
Edit: fixed color tags.
hamza
Sat Apr 11, 2015 7:45 pm
yes I have european PAL Tv also I put it on the right av input
I did not try your commands becouse the screen did not recive any signal...so can I Test them on hdmi connection??
Anyway if there is no additional software settings ...so i think the peoblem will be in the hardware...I will try to test some test pads.
