vamp
MHL support
Thu Apr 09, 2015 12:30 pm
Does the Raspberry Pi 2 support MHL?
drgeoff
Re: MHL support
Thu Apr 09, 2015 5:09 pm
No.
(What is the reason for your question?)
vamp
Re: MHL support
Sat Apr 11, 2015 12:10 am
i want to split an image and output the splitted images on different screens. and the pi has only one hdmi port, i wanted to use the USB ports instead and then use a usb to hdmi cables.
Re: MHL support
Sat Apr 11, 2015 3:39 am
vamp wrote:usb to hdmi cables.
Can you post a link to this product ?
Retired disgracefully.....
drgeoff
Re: MHL support
Sat Apr 11, 2015 8:31 am
vamp wrote:i want to split an image and output the splitted images on different screens. and the pi has only one hdmi port, i wanted to use the USB ports instead and then use a usb to hdmi cables.
MHL is irrelevant in that context.
When you plug a MHL cable into the micro-USB socket of a device that has MHL that USB socket changes mode and no longer outputs USB signals.
ragnarjensen
Re: MHL support
Sat Apr 11, 2015 2:43 pm
This is what I use. I have a bunch of them.
http://www.ebay.com/itm/USB-2-0-UGA-To- ... 233e40e597
"USB DisplayLink" is the phrase to put into your search engine.
Ragnar
Re: MHL support
Sat Apr 11, 2015 2:54 pm
Ragnar
That is a USB Graphics Adaptor, the OP stated USB to HDMi Cable which I have never seen, different altogether :)
ragnarjensen
Re: MHL support
Sat Apr 11, 2015 3:05 pm
Yes, I know :) I haven't seen that kind of cable either.
Since it's already established that MHL isn't relevant, I just wanted to point out something I know actually works.
Ragnar
ghans
Re: MHL support
As said , this only works with the special "MHL" USB ports
which the Pi doesn't have :
http://www.amazon.com/Samsung-MHL-HDMI- ... B005LGUDKK
ghans
Re: MHL support
Sat Apr 11, 2015 3:54 pm
ghans wrote:As said , this only works with the special "MHL" USB ports
ghans
That is not a cable it is a convertor/adaptor ;)
ghans
Re: MHL support
Sat Apr 11, 2015 4:16 pm
Oh yeah , MHL (which is not USB , but may be found on USB ports) works like that.
ghans
Bruny
MHL PiPhone
Mon Apr 13, 2015 10:38 am
