y2kats65
rpio-curses on RPI 2
Tue Apr 07, 2015 12:28 am
I installed the RPIO using the following instructions on a RPI 2.
$ sudo apt-get install python-setuptools
$ sudo easy_install -U RPIO
I then ran "rpio-curses". It came back with the error:
"SystemError: This module can only be run on a Rasperry Pi"
Will this run on a Raspberry Pi 2?
AndyD
Re: rpio-curses on RPI 2
Tue Apr 07, 2015 1:07 am
Have a look at this thread for information about updating RPIO for the Pi 2.
y2kats65
Fri Apr 10, 2015 1:22 pm
Thank you. I followed the thread and installed all required packages. I still got the same error.
joan
Fri Apr 10, 2015 1:26 pm
The RPIO module has not been fully updated for the Pi2. Servo/PWM pulses and DMA in general does not work on the Pi2.
I assume rpio-curses has a similar problem.
