Konintersector
Rasp pi 2 SD Question
Fri Mar 20, 2015 5:40 pm
I am new user of the rasp pi 2 i await its arrival next week and I am a bit confused about the SD.
So, is it compatible only with the microSD? Or can i use a SD, too?
I searched the forum but I wasn't getting a clear answer about it.
Thank you in advance
electronicsguy
Re: Rasp pi 2 SD Question
Fri Mar 20, 2015 6:36 pm
Konintersector wrote:Hello,
Only microsd. But much easier if you use the microsd just for initial boot, and put all data and the root partition on a mini USB drive.
blog: https://electronicsguy.wordpress.com
github: https://github.com/electronicsguy
FTrevorGowen
Fri Mar 20, 2015 8:56 pm
FWIW, the NOOBS installer is usually supplied on a Samsung 8Gb, class 6 uSDHC card + adapter and I've successfully used all the uSDHC card types and classes shown here:
http://www.cpmspectrepi.webspace.virgin ... cards.html
Go with a supplier "you know" at a price you consider fair - w.r.t. to the larger (>=32Gb) card sizes beware of cheap cards from "dubious sources", there are fakes "out there".
Trev.
