BillyBag2
wifi "Roaming"
Fri Jul 06, 2012 3:46 pm
I've got the RPi connected to my WiFi network. What I would like it to do it attach to any of a preconfigured list of WiFi networks automatically. At startup would be good. Dynamically attaching to another network if one is lost would be even better. I run the RPi headless using vnc and would like to just power it on and it attach to a known network. I could setup a hot spot at a new location to get in and then would like to add the new location's WiFi to the list.
Pi N Chips - pinchips.blogspot.co.uk
Nr90
Re: wifi "Roaming"
Fri Jul 06, 2012 9:40 pm
WICD gives you an easy way to choose which networks to connect to.
It might do roaming aggressiveness as well, but I don't know.
Crazysilverwolf
Re: wifi "Roaming"
Mon Jul 09, 2012 5:00 pm
Can I ask what make and model of wifi adapter your using?
Cheers Daz
BillyBag2
Re: wifi "Roaming"
Tue Jul 10, 2012 10:04 pm
I purchased a cheap unpranded mini wifi adapter off eBay. They all seam to use the same chip set. I got one with "n" and it was not much more. If you are waiting for your RPi then consider the saving getting one from china etc. If you have a RPi then aim for a local supplier as it will arive a lot more quickly. I will try to remember to post more details of the install process.
BillyBag2
Re: wifi "Roaming"
Tue Jul 10, 2012 10:47 pm
Wicd works well. Did not seam to switch from one network to another. The wifi drivers for my wifi dongle seam to be ore installed on wheezy.
burgergetsbored
Re: wifi "Roaming"
Sun Jul 29, 2012 5:28 pm
BillyBag2 wrote:I purchased a cheap unpranded mini wifi adapter off eBay. They all seam to use the same chip set. I got one with "n" and it was not much more. If you are waiting for your RPi then consider the saving getting one from china etc. If you have a RPi then aim for a local supplier as it will arive a lot more quickly. I will try to remember to post more details of the install process.
I don't suppose you could send me an exact link to the same one you bought please? I've found ones like these but I'm not sure if they'll work or not: http://www.ebay.co.uk/itm/WIFI-150MBPS- ... 070wt_1037
BillyBag2
Re: wifi "Roaming"
Wed Aug 08, 2012 12:15 am
Sorry for delay, this is the one I got...
http://www.ebay.co.uk/itm/180907070265? ... 025wt_1202
burgergetsbored
Re: wifi "Roaming"
Wed Aug 08, 2012 10:15 am
No worries still waiting for my pi in the post! Just thought I'd get the equipment before it arrives! Cheers !
