Silverclaw666
Accessing raspberry webserver via hamachi
Mon Mar 16, 2015 8:00 am
Hello, I have a short question for you and hope you can help me.
I got myself a raspberry and installed apache,mysql etc. on it. I can access it with any pc in the same network, no problem. However I would like to access my raspberry even if im not in the same network, via hamachi. So I installed hamachi on the raspberry, installed hamachi on my pc and connected both to the same hamachi network. But, if I want to access the webserver or even ping the raspberry it only give me a timeout respectively just doesn't work. Anyone of you got an idea how I can make this work, or why it doesn't work?
Sandbird
Re: Accessing raspberry webserver via hamachi
Fri Mar 20, 2015 12:43 pm
not sure about hamachi but you can port forward port 80 to your pi's lan ip and then you will be able to access the webserver from outside your network.
Probably hamachi needs a port forward as well.
