Robbi_Blechdose
Can the Pi take 5800 mAh?
Wed Mar 11, 2015 2:51 pm
Hello all,
is the Pi able to be powered safely from a 5v 5800 mAh USB port?
Robbi Blechdose
benjinight
Re: Can the Pi take 5800 mAh?
Wed Mar 11, 2015 2:54 pm
Robbi_Blechdose wrote:Hello all,
Robbi Blechdose
It's not possible to have a USB port with 5800mAh, because it's a quantity of a charge (for a battery, for the example).
But it's possible that your USB port have 1 or 2 A. You should put your Rpi on 2A if you have several boards connected on it.
Regards.
Robbi_Blechdose
Wed Mar 11, 2015 2:58 pm
Well,
this one seems to have 5800 mAh: http://www.amazon.de/Wiederaufladbares- ... v+usb+akku.
Robbi Blechdose
mott555
Wed Mar 11, 2015 3:00 pm
The mAh rating of the battery indicates how long the battery's charge will last when used. Higher values means the battery lasts longer. It has nothing to do with safety or the Pi's power requirements.
Robbi_Blechdose
Wed Mar 11, 2015 3:01 pm
Ok,
cool. So I could use that to build some sort of Pi-Laptop?
Robbi Blechdose
mikronauts
Wed Mar 11, 2015 3:02 pm
I run my Pi robots from 5200mAh and 12000mAh USB chargers (depending on bot), so yes, it will work.
Robbi Blechdose
RaTTuS
Wed Mar 11, 2015 3:04 pm
you are confusing apples and oranges [well not but you'll see]
the RPi takes 5V +/- 5%
so you can power it from a voltage range 4.75V to 5.25V
but you need 800mA [approx] to keep it going
batteries have ratings in mAh [milli Amp Hours] and chage banks with usb sockets will output 5V
the
1000mAh
1500mAh
5000mAh
15000mAh
50000mAh
all relate to how long it can deliver the amount of mili Amps on that connection
understand ?
Covfefe
benjinight
Wed Mar 11, 2015 3:07 pm
It's good for your application.
Regards.
