duzuike
Which charger is better ?
Thu Mar 05, 2015 6:26 am
I have 2 mobile phone chargers. Here is the test result :
Voltage (GPIO pin2 and pin14)
ZTE charger: 5.18v
HTC charger: 4.94v
Which one should I choose to power Rpi ? Is the ZTE charger safe ?
rpdom
Re: Which charger is better ?
Thu Mar 05, 2015 6:46 am
Either one should be fine. Both are within the recommended range of voltage supply to the Pi (4.75 to 5.25v). I'd say that a better range would be 4.9 to 5.2v, as lower voltages can mean the supply isn't up to the job when loaded heavily.
Just make sure the voltage stays in that range when everything is plugged in and up and running.
FTrevorGowen
Thu Mar 05, 2015 10:56 am
duzuike wrote:Hi,
ZTE charger: 5.18v
HTC charger: 4.94v
Since you don't say which model of HTC charger, if it happens to be this type:
http://www.cpmspectrepi.webspace.virgin ... TC_TC_B250
I would favour the ZTE one.
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
duzuike
Thu Mar 05, 2015 1:22 pm
FTrevorGowen wrote:
duzuike wrote:Hi,
ZTE charger: 5.18v
HTC charger: 4.94v
Trev.
Yes. After read that page , I think the ZTE charger is better.
Return to “Beginners”
