How to exit x?
Posted: Wed Jul 04, 2012 10:33 pm
by Mortimer
How to get into the GUI is obvious, the RPi even tells me after every boot and login.
Is there a way to exit the GUI and return the command line?
Re: How to exit x?
Posted: Wed Jul 04, 2012 10:38 pm
by Joe Schmoe
Switch back to the console from which you started X (Ctrl/Alt/F1) then hit ^C.
Re: How to exit x?
Posted: Wed Jul 04, 2012 10:53 pm
by penguintutor
Choose logout from the program menu - or the red power off button in the bottom right - it will then return you back to the shell.
Re: How to exit x?
Posted: Wed Jul 04, 2012 10:54 pm
by Nr90
Open up terminal and type pkill x
Re: How to exit x?
Posted: Wed Jul 04, 2012 10:55 pm
by Mortimer
Thanks that works.
What does the LXDE logout menu option actually do, because that seems to kill the RPi? I would have expected that to drop me back out to the command line.
Re: How to exit x?
Posted: Wed Jul 04, 2012 11:25 pm
by Joe Schmoe
Mortimer wrote:Thanks that works.
Which 'that'?
Mortimer wrote: What does the LXDE logout menu option actually do, because that seems to kill the RPi? I would have expected that to drop me back out to the command line.
According to the parallel thread on this topic, that no workie and is to be avoided.
Re: How to exit x?
Posted: Wed Jul 04, 2012 11:50 pm
by Mortimer
Which 'that'?
Sorry the ctrl-alt-F1, ctrl-C method worked for me.
I didn't notice the pkill x post from Nr90, but I have no reason to suspect that won't work either.
Re: How to exit x?
Posted: Thu Jul 05, 2012 12:03 am
by clickykbd
that parallel thread is here:
http://www.raspberrypi.org/phpBB3/viewt ... 63&t=10227
Re: How to exit x?
Posted: Thu Jul 05, 2012 12:37 am
by grumpyoldgit
Mortimer wrote:
Which 'that'?
Yeah. This has only been a development in the last few days if the Pi is kept up to date. Previously you could just exit from x and had to give a sudo halt to close it down.
Re: How to exit x?
Posted: Thu Jul 05, 2012 7:45 am
by penguintutor
The logout menu option should work. I hadn't noticed a problem before, but then once I've gone into x I don't normally come out of it much and I usually access the Pi remotely.
I've just tried a few times and sometimes it works and other times it's crashing (unable to connect by network so it's not just the screen session that's hanging).
There is already a bug report for this for Wheezy:
https://github.com/asb/spindle/issues/79
Re: How to exit x?
Posted: Thu Jul 05, 2012 8:16 am
by Mortimer
I didn't know about ctrl-alt-backspace, that works for me too.
Re: How to exit x?
Posted: Thu Jul 05, 2012 8:45 am
by clickykbd
For others reading, If ctrl-alt-backspace doesn't do it for you, you may have opted to exclude it in your keyboard configuration step, which you can redo using the raspi-config script or
sudo dpkg-reconfigure keyboard-configuration
Re: How to exit x?
Posted: Thu Jul 05, 2012 9:42 pm
by Babbage6913
Have also had some problems with the Pi hanging on reboot
So today, I setup 2 different SD cards
First card was a 2GB integral, and I just re-imaged via win32image. Then I did my standard setup as follows:
Boot then reboot to set the card up, get rid of nfs fails etc. BTW using Debian image from download section.
Then I 'sudo apt-get update' twice. First time to update, second to clear errors. If I then 'startx' everything is fine, reboot menu option works ok, as does 'sudo reboot'.
Then I 'sudo apt-get upgrade' and reboot. Now if I 'startx' using the reboot option on menu gets through the shutdown sequence to the 'system halted' ok. Then the composite signal drops and the Pi hangs, all leds lit and doesn't reboot. Same if I 'sudo reboot'. Or doesn't bring composite signal back up. I think the Pi is booting as all the leds do what they normally do. Not sure if this is what others are getting.
Second card, 4GB PNY, I reformatted back to FAT32, then re-imaged the Debian.
This time I did the 'sudo apt-get update', again twice. Then I did the steps needed to run rpi-update.
Once rpi-update finishes, reboot, after 'startx' everything is fine. Using the reboot menu option works, as does 'sudo reboot'.
If I type 'sudo shutdown -h -P now' the Pi shuts down, after 'system halted' appears, composite signal drops, network leds go off, ok flashes then left with just power led lit.
Re: How to exit x?
Posted: Tue Dec 11, 2012 1:05 pm
by NADinmore
Thanks for the tips on exiting X with keyboard shortcuts. I started my (son's) RPi yesterday, but something happened to the display in the GUI and the menu bar at the bottom disappeared...(I tried changing the TV aspect ratios to no avail).
Any tips on resolving this would be appreciated!
Re: How to exit x?
Posted: Tue Oct 15, 2013 3:53 am
by UsedBits
My pi is headless. It is accessed from my Windows XP box via Putty and TightVNC.
I made the mistake of logging out of the X screen via the 'red power button' at the bottom right-hand corner of the virtual window. The desktop, the one with the huge raspberry in the middle, remains, but all of the desktop icons are gone. That said, can still work the desktop from the bottom left-hand corner of the windows, e.g. all of the menu items pop up and are active. Ctrl-alt-backspace does nothing, as does ctrl-alt-F1.
How does one log back in? I'd like to access those desktop icons.
Oh, once logged out of the desktop, the red power button is replaced by a little green running man.
From the 'run' command, one can run 'lxde-logout', but there appears to be no corresponding 'lxde-login'.
I've tried terminating and restarting tightvncserver, and rebooting the pi. Nothing, so far, has been able to restart a remote X session with the desktop icons restored.
Re: How to exit x?
Posted: Tue Oct 15, 2013 7:28 am
by Davespice
UsedBits wrote:My pi is headless. It is accessed from my Windows XP box via Putty and TightVNC.
You don't actually need to log out of X using the menu, you can just close your VNC viewer program on Windows and use this command in Putty.
vncserver -kill :1
Re: How to exit x?
Posted: Tue Oct 15, 2013 11:33 am
by UsedBits
But I already *have* logged out. And killing the X, then restarting, doesn't reinstate the desktop icons.
So, again, how does one log back into the X screen after having logged out via the 'red power button' at the bottom right-hand corner of the screen?
Re: How to exit x?
Posted: Wed Nov 23, 2016 10:01 pm
by anonymous6546
Killall5 into the run box on menu or in terminal
Re: How to exit x?
Posted: Sun Dec 18, 2016 2:12 am
by brat.ibr
RPi 3 running Jesse connected to monitor via HDMI cable
Go to Menu (top left corner of the X screen)
Click Shutdown
which will provide you with Three options :
Shutdown -or- Reboot -or- Exit to command line
Re: How to exit x?
Posted: Sun Dec 18, 2016 8:59 am
by PeterO
anonymous6546 wrote:Killall5 into the run box on menu or in terminal
Before you reply to any more threads, please check how old they are. This thread had been dead for 3 years !!!
PeterO
Re: How to exit x?
Posted: Tue Jan 24, 2017 5:54 pm
by hcostelha
I know this is an old thread, but since it is the top result when searching for it online, here goes my suggestion:
sudo service lightdm stop
Using "pkill x", Ctrl+Backspace or similar is not the best option, since X is restarted immediately.
Of course there is always the option to disable starting X automatically.
Re: How to exit x?
Posted: Wed Jan 25, 2017 1:01 am
by Martin Frezman
It depends on why you are doing it. I.e., what the overall goal is.
Usually, when I want to "exit X", the reason I am doing it is precisely so that it will restart. I.e., it has gotten mucked up and I want a fresh start.
If your goal is to change your system so that it no longer runs the GUI, then your method will work, but your method is just the "hands on" way of doing what the clicky-clickly folks do in either the text mode or GUI version of "raspi-config". Of course, I suppose your method has the benefit that it takes effect immediately, while the raspi-config method requires a reboot (I have not tested this).
Anyway, whatever works... Note that the original post was created well before Raspbian did either of these things:
1) Ran systemd
2) Booted automatically (in the default, out-of-the-box setup) into a GUI
Re: How to exit x?
Posted: Wed Jan 25, 2017 2:44 am
by hcostelha
Martin Frezman wrote:[...]
Note that my suggestion only stops X for the current "session". If you reboot it will start normally. Changing in raspi-config disables it until you change the configuration again.
Re: How to exit x?
Posted: Sun Sep 17, 2017 7:11 pm
by adamreisnz
Running pkill x through ssh (or in the background) was the only one that worked for me.
The keyboard combinations had no effect whatsoever.
