Wed Mar 04, 2015 3:43 pm
Hello all, I have been having some issues with my pi ever since I wiped the SD card and reinstalled raspbian. I have been using a usb battery pack with my pi and I almost never had any issues with it, the voltage is pretty stable, hovering around 5.1x volts, but after the wipe the rainbow square is always on and never leaves. Normally I have a Bluetooth adapter and a wifi adapter plugged in, and maybe a flash drive, but now it hangs after starting the swap file if I have any of them connected. Basically, the only thing that has changed is that I have updated the software, and I have no reason to believe the problem is with the hardware, and yes, I have tried using a wall charger, specifically, an 12 watt iPad brick. Can you help me?
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
Scott Adams
