dhruvvyas90
Determining Rpi revision in kernel driver module.
Wed Mar 04, 2015 1:07 pm
I am sort of new to driver development in Linux. I'm trying to write a driver for an I2C device and as it turns out, Rpi revision 1 uses i2c bus 0 and revision 2 uses i2c bus 1. I was wondering if there is a way to determine Rpi revision run time or compile time in a kernel module (both are fine).
Thanks in advance.
ShiftPlusOne
Re: Determining Rpi revision in kernel driver module.
Wed Mar 04, 2015 3:11 pm
The 'simple' way is to check the board rev. I think there's a nicer way to do it using device tree (but I don't know what that is).
