bobo10
snappy ubuntu login/password on start up???/
Sat Feb 21, 2015 9:31 am
snappy ubuntu login and password???
Re: snappy ubuntu login/password on start up???/
Sat Feb 21, 2015 1:18 pm
bobo10 wrote:snappy ubuntu login and password???
On the http://www.raspberrypi.org/downloads page if you clicked on the More Info + it will expand the details of the download:
SNAPPY UBUNTU CORE
Snappy Ubuntu Core for Developers
Version:alpha-02
Release date:2015-02-03
Default login:ubuntu / ubuntu
URL:ubuntu.com
Kernel version:3.18.0
Download TorrentDownload ZIP
SHA-1:4ca8ea6b694ad644cf4b00337a625b28bc8f8455
Pi Version supported:Pi 2 only
My only "PC" is an Asus ChromeBit running ChromeOS, cloudcentric at its best !
Rockchip Quad-Core RK3288C ARM32 SoC as used in ASUS Chromebook C201 & Chromebook Flip C100PA as well as the Tinker SBC.
3 Mobile Huawei E5330 Mobile Mi-Fi
jerobillard8
Fri Feb 27, 2015 9:41 pm
Login: ubuntu
Password: ubuntu
what to do after that, I'm not sure.
Fri Feb 27, 2015 10:58 pm
jerobillard8 wrote:Login: ubuntu
Password: ubuntu
You go to the Snappy Core Website and start developing "Cloud Apps & IoT Apps"
https://insights.ubuntu.com/2015/02/02/ ... berry-pi-2
http://developer.ubuntu.com/en/snappy
isimorgh
Mon Nov 14, 2016 12:46 am
Hi all,
I followed the instruction on https://developer.ubuntu.com/en/snappy/ ... erry-pi-2/
During the first boot it asked me to press enter to configure and later it asked me to enter my email address from my account in the ubuntu store. I did import an SSH Key into my Ubuntu SSO account already. After entering my email it connected to the store and then I got the 'Configuration Complete' screen, saying that remote access was enabled via authentication with SSO user <isimorgh> .
The green 'Finish' button was highlighted so I pressed Enter.
The next screen is 'Ubuntu Core 16 on 10.0.1.125 (tty1)'
I entered my username from the SSO account, isimorgh, and my password for SSO account, but the login is incorrect!? :?
I even tried my email address as login name.
Have I done anything wrong?
Appreciate any help.
Thanks in advance.
rafapira
Fri Nov 18, 2016 7:41 pm
Hi, exactly same issue as the friend above.
Does anyone have an idea what we could do?
isimorgh
Fri Nov 18, 2016 8:43 pm
@rafapira
It seems like it's not a common incident, but I don't know how to fix it.
andrefelipecl
Sat Dec 03, 2016 10:21 pm
Hi, guys.
I'm in the same problem. I created a SSO account; I generated a SSH Key; and so I logged in Ubuntu Core with my SSO email and now I can't login on ubuntu core...
I'm looking for something and if I found, I'll post here.
Hugs
waleedqk
Tue Dec 20, 2016 10:15 pm
Since I could not log in and was facing the same problem as you guys I used the ssh connection to create a root user with the username on the Ubuntu SSO account:
adduser username
In my case it gave a conflict saying that the username already existed. Since I couldn't figure out the password for it, I changed it:
sudo passwd username
Note: these commands were run from the ssh connection to the pi.
aldelbal
Fri Jan 06, 2017 9:19 pm
Hello, I have the same problem. After installation and download of SSH pub key into raspberri I cannot login from console nor ssh.
In case of ssh I am always asked to enter password which does not work.
Any help?
Thanks folks.
aldelbal
Tue Jan 10, 2017 8:12 pm
I wanted to give an update on the situation. I did two things:
1. Redid the SSH key as I did not use the correct format.
2. During login it might take few tries until it works well. After some time I could login without password as intended.
Cheers
mhelmer
Wed Aug 09, 2017 5:10 pm
What was the correct formatting for the SSH key?
Who is online
Users browsing this forum: scruss, UF_DoC and 59 guests
