How to connect RPi A+ to MacBook Pro?
Posted: Fri Feb 20, 2015 11:00 pm
by GabrielT
I am 11 and I have a little knowledge of python. I got my new Raspberry Pi A+ and I wanted to connect it to my mac but I don't know how, I have already installed the operating system using but I cannot use it for much longer because the monitor has to go back to my dads work. How am I meant to connect it to a macbook pro?
I would really appreciate your help!
Re: How to connect RPi A+ to MacBook Pro?
Posted: Fri Feb 20, 2015 11:22 pm
by fruitoftheloom
GabrielT wrote:I am 11 and I have a little knowledge of python. I got my new Raspberry Pi A+ and I wanted to connect it to my mac but I don't know how, I have already installed the operating system using but I cannot use it for much longer because the monitor has to go back to my dads work. How am I meant to connect it to a macbook pro?
They need to be networked together, SSH/VNC
http://www.raspberrypi.org/documentatio ... /README.md
Posted: Sat Feb 21, 2015 5:27 am
by GabrielT
Thanks, but the pi does not have ethernet connection, how do I network it?
Posted: Sat Feb 21, 2015 5:52 am
by fruitoftheloom
GabrielT wrote:Thanks, but the pi does not have ethernet connection, how do I network it?
USB to Ethernet Adaptor
Posted: Sat Feb 21, 2015 6:11 am
by GabrielT
thank you very much for your help!!
Posted: Sat Feb 21, 2015 6:17 am
by jimallyn
I bought an RPi kit that included a wifi dongle, and that's what I use to connect it to the network. I have no monitor, mouse, or keyboard on the RPi, so I access it from my desktop computer via ssh and VNC. The RPi has ssh enabled by default, and you can connect to it via another computer on the network, like this:
ssh pi@xxx.xxx.xxx.xxx
where xxx.xxx.xxx.xxx is the network address of your RPi. (It will probably be something like 192.168.1.101. Check your router setup to be sure.) Once you have connected to the RPi by ssh, if you don't already have the xserver (graphic mode) running, execute 'startx' (without the quotes). Then execute 'sudo apt-get install tightvncserver' (without the quotes) to install the VNC server, which I think is not enabled by default. I think I had to manually start tightvncserver but I don't remember for sure. Then connect to the RPi over the network from another computer on which you have installed a VNC viewer application. The viewer I use (in Linux Mint) is just called vncviewer, and I connect to the RPi by executing 'vncviewer xxx.xxx.xxx.xxx:1' (again, without the quotes). You now have terminal mode and graphic mode access to your RPi. (I may have left something out, but this is most of what you need to know, anyway.)
Posted: Sat Feb 21, 2015 7:45 am
by DougieLawson
Use a ftdi USB to 3V3 serial cable on your PC and the Raspberry serial console on the UART.
http://pi.gadgetoid.com/pinout/uart
Posted: Sat Feb 21, 2015 7:49 am
by fruitoftheloom
DougieLawson wrote:Use a ftdi USB to 3V3 serial cable on your PC and the Raspberry serial console on the UART.
He is using a MacBook Pro not a PC !
Posted: Sat Feb 21, 2015 7:50 am
by DougieLawson
Some strange Apple devices still have USB.
Posted: Sat Feb 21, 2015 7:53 am
by fruitoftheloom
That was not what you stated, it was PC, so corrected for completeness, of course Apple Computers have USB
Posted: Sat Feb 21, 2015 8:11 am
by jimallyn
PC stands for Personal Computer. A Mac isn't a Personal Computer?
Posted: Sat Feb 21, 2015 1:02 pm
by mahjongg
YES, a mac IS a personal computer, though people often ignore that and use the two letter dominator "PC" to mean windows personal computers exclusively, ignoring any other types of personal computers out there, like Linux based systems. When the say "PC" they actually mean a "WINTEL" system.
(saying this is to kick in an open door, obviously)... :mrgreen:
Posted: Sat Feb 21, 2015 1:24 pm
by fruitoftheloom
mahjongg wrote:YES, a mac IS a personal computer, though people often ignore that and use the two letter dominator "PC" to mean windows personal computers exclusively, ignoring any other types of personal computers out there, like Linux based systems. When the say "PC" they actually mean a "WINTEL" system.
I originally posted to wind up DL as he often winds up other posters and felt he deserved his own medicine :D
...but jimma was not aware of this obviously ;)
All computers you own are personally yours :!:
Posted: Sat Feb 21, 2015 2:14 pm
by pluggy
The Pi A+ is a fabulous device, but its a lot easier to configure it on a B+ / Pi2 and then swap the SD card over....
Connecting it up 'cold' doesn't appeal. It can be done but its far from noob territory IMO.
Always buy the A+ as a second Pi.
'PC' has widely although incorrectly IMO come to mean a Wintel machine.
I use some kind of crazy hybrid - a Wintel without the Win
Posted: Sat Feb 21, 2015 2:19 pm
by DougieLawson
fruitoftheloom wrote: I originally posted to wind up DL as he often winds up other posters and felt he deserved his own medicine :D
You're going to struggle in that quest, this is only an internet forum.
