Mortimer
Mounting and Umounting CIFS Shares
Tue Jul 03, 2012 11:27 am
I have a small IOMega Network drive, that I thought would be useful to transfer stuff to and from the RPi.
The network drive is on IP address 192.168.1.250 and amongst the several shares on it, there is one called "General".
I made a directory in /media called General and did the following:
sudo mount -t cifs //192.168.1.250/General /media/General
Lo and behold I was able to list the files on the network drive.
Ok, now to unmount the share, I tried:
sudo umount /media/General
Only to be told:
umount: /media/General: device is busy.
(In some cases useful info about process that use
the device is found by lsof(8) or fuser(1))
fuser -m /media/General
returns
/media/General: 1503c
ps | grep 1503
tells me that the process using the share is the current terminal session. Only to be expected, but all I have done is list files in the share, not opened any files or anything like that.
How do I get the current session to release its hold on the shared volume? Do I have to exit session and log back in? Surely not?
The purpose of a little toe is to ensure you keep your furniture in the right place.
Mortimer
Re: Mounting and Umounting CIFS Shares
Tue Jul 03, 2012 11:33 am
It's OK I sussed it...
The terminal session had the current working directory set to the shared folder. Just CD'd to home, and the umount command worked after that.
Doh!! :oops:
Joe Schmoe
Tue Jul 03, 2012 11:48 am
Yes. Note that the "c" in the fuser output indicates "current directory".
Mortimer
Tue Jul 03, 2012 11:52 am
Thanks, useful to remember.
Mortimer
Tue Jul 03, 2012 1:01 pm
OK, I might as well see if I can learn some more from this...
Is there a way in Debian to see what shares are available on a given IP address?
For example I know that my IOMega has several shared folders, but supposing I didn't know, could I find out using my RPi as a terminal?
SirLagz
Tue Jul 03, 2012 2:21 pm
When you say "RPi as a terminal", I assume you mean from the command line ?
I don't know anything for sure, but you could try these packages which I've just looked up
smb2www <-- browse samba shares via a web browser.
smbc <-- that looks promising. samba-commander - a ncurses based samba client
My Blog - http://www.sirlagz.net
Visit my blog for Tips, Tricks, Guides and More !
WiFi Issues ? Have a look at this post ! http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=44044
Mortimer
Tue Jul 03, 2012 2:49 pm
I installed smbc and typed in smbc [return], and nothing.
The prompt doesn't return, and doing 'top' in another terminal shows smbc consuming 68% CPU.
I don't want a GUI solution so haven't looked at smb2www.
Hiro
Sat Jul 07, 2012 4:12 pm
I wanted to see all the shares on my network from the cli a while ago and i used "smbtree -N" Would this do for you?
Return to “Beginners”
