Bmccall
What is pi capable of
Tue Sep 14, 2021 8:06 pm
Hi I’m new to the pi scene and I have a project to create for collage,
I am wondering if it is capable of 2 cameras
Camera 1: for lane assist
Camera 2: monitoring facial expressions
Both of the above at the same time
Also running multiple programs in the one instance,
My project is to monitor a drivers vitals both through cameras and sensors, then interact via canbus in the car,
Any info would be helpful
HermannSW
Re: What is pi capable of
Tue Sep 14, 2021 8:25 pm
In case you want to use two Raspberry cameras at the same time, you would need a Raspberry Compute Module -- all other PIs support only a single CSI camera. Adding USB camera(s) allows to satisfy your requirement for normal PIs.
Raspberry Pi OS is Linux -- you can run many programs at once (even on single core Pi0). Newer Pi models all have 4 cores:
https://www.raspberrypi.org/products/
https://stamm-wilbrandt.de/2wheel_balancing_robot
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/en/Raspberry_camera.html
Bmccall
Tue Sep 14, 2021 8:40 pm
Thanks for the reply👍
Have 6 months to complete, so all help is greatly appreciated
Gavinmc42
Wed Sep 15, 2021 4:54 am
Those apps don't need high resolution.
Even 320x240 might be enough.
Arducam have a bunch of cameras down to SPI ones even a Pico can use.
2 x CSI cameras and 6 SPI cams?
Even more if you use their CSI mux boards.
Libcamera now has a detect app, might be a place to start.
https://github.com/raspberrypi/libcamer ... /main/apps
I'm dancing on Rainbows.
