thagrol
STICKY: Running A Program At Start UP A Beginner's Guide
Wed Jun 23, 2021 2:51 pm
Number four in an occasional series.
boot.zip
(169.63 KiB) Downloaded 78 times
Also on github: https://github.com/thagrol/Guides
I'm a volunteer. Take me for granted or abuse my support and I will walk away
All advice given is based on my experience. it worked for me, it may not work for you.
Need help? https://github.com/thagrol/Guides
neilgl
Re: Running A Program At Start UP A Beginner's Guide
Wed Jun 23, 2021 3:40 pm
Excellent stuff, thanks.
deepo
Wed Jun 23, 2021 6:51 pm
That's good work!
katesimon123
Wed Jun 23, 2021 7:52 pm
Good one, will test it out !!!
RonR
Wed Jun 23, 2021 8:25 pm
A && B || C : Do A, if A succeeds do B. If A failed do C
I believe this should be:
A && B || C : Do A, if A succeeds do B. If A or B failed do C
root@FreePBX:~# true && true || echo "!"
root@FreePBX:~# true && false || echo "!"
root@FreePBX:~# false && true || echo "!"
root@FreePBX:~# false && false || echo "!"
thagrol
Wed Jun 23, 2021 9:28 pm
Probably. Feel free to open an issue in my github.
bls
Wed Jun 23, 2021 9:40 pm
This is great, thagrol!
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
strantor
Re: STICKY: Running A Program At Start UP A Beginner's Guide
Thu Jul 08, 2021 7:20 pm
Very well put together and extremely helpful. Thank you so much for this resource! It got me where I needed to be in minutes, after wasting hours trying to follow other advice.
Return to “Beginners”
