zzk
USB keyboard on Pi 400 desktop
Thu May 13, 2021 2:45 pm
Hi all
I am new here, and I am about to buy a Z6415 • Raspberry Pi 400 Desktop Computer to set it up for my TV as an entertaining system (youtube/netflix) and a bit of gaming via steam link.
However I have got a question - since this model is already built with a keyboard - is it possible if I can connect another usb keyboard to it (gaming keyboard)?
Thanks in advance !
davidcoton
Re: USB keyboard on Pi 400 desktop
Thu May 13, 2021 2:47 pm
Yes, you can connect a USB keyboard. No guarantee that the driver will recognise all the keys, though.
zzk
Thu May 13, 2021 2:56 pm
davidcoton wrote: Yes, you can connect a USB keyboard. No guarantee that the driver will recognise all the keys, though.
Thank you for your swift response!!!
my goal with the pi is to setup steamlink for gaming, and also to use netflix/youtube
I have seen it works with steamlink to run many games like Dota 2
btw - does the latest Rasberry Pi OS can run both netflix and youtube on Chromium? I have checked some online tutorials - it seems like i need to update and upgrade the apps like the widevine content?
davidcoton
Thu May 13, 2021 2:58 pm
No idea -- I don't use Netflix, YT, or Chromium if I can avoid them.
Thu May 13, 2021 3:35 pm
chromium-browser supports Youtube play back, though you may need to change format to lower quality.
Netflix requires Widevine DRM, if not installed then:
sudo apt update
sudo apt install libwidevinecdm0
https://bitmovin.com/demos/drm
My other Linux machines: ChromeBox
https://www.aliexpress.com/item/32966393971.html
& Stone Desktop Intel CoreDuo circa 2010
Dragontail281
Thu May 13, 2021 5:06 pm
Just throwing this out there.
If you are going to use a different keyboard, why not get a RPI4 8GB instead of the 400?
RPI3B+ - Raspberry Pi OS -general "playing" and/or RetroPi
RPI0W#1 - MotionEyeOS - yard/home brew surveillance
RPI0W#2 - PiOS/Driveway gate monitor - work in progress
RPI0W#3 - ?????
zzk
Fri May 14, 2021 2:29 am
hi
I actually thought about it, but the local store here is selling it for $144 where the 400 is only 125 :(
i have gone through a check list and i think 400 fits most of my needs plus i can take it around with me without an additional keyboard.
just got the 400 and got everything setup as the way i wanted - steamlink + netflix - perfect !
bjtheone
Fri May 14, 2021 11:52 am
sudo apt update
NOt sure what the exact current state is. Last time I tried it (at least a month ago) the default chromium install from the repo supports Netflix's but only at a lower resolution , 720 instead of 1080 (this is a limitation Netflix imposes on the hardware). I also noticed a bit of lagging/stuttering. While I am not sure why it seems to have some performance issues, the resolution downgrade is unlikely to be addressed since it comes from Netflix and you have to "lie" about your hardware via the user agent to work around it.
The work around is the tweaked install that has a different widevine lib and a altered user agent that claims to be a Chromebook. That verison plays nicely at 1080.
The two verisons (default and "media") happily co-exist on the same install.
Fri May 14, 2021 12:50 pm
sudo apt update
As I have a 3B+ quite happy to use what RPT / RPF offer by default, rather than the Botspot / Petrov alternative Widevine DRM implementations....
....each to their own.
zzk
Fri May 14, 2021 3:04 pm
can you please advise how to replicate the above method?
I have got netflix running - noticed the lagging/stuttering - but it happens here and there so it doesnt bothering me too much - however it will be nice to be able to run it smoothly
Return to “Beginners”
