MinistryofSillyWalks
WPA_GUI Popup in Kiosk Mode if no Wifi
Wed May 12, 2021 11:55 am
Hi there,
I wanted to use wpa_gui in conjunction with our Buster/Chromium - based kiosk mode.
So far I have achieved adding a simple command that checks if there is an internet connection, and if there is not, it will open the wpa_gui:
#!/bin/bash
set -o errexit    # Used to exit upon error, avoiding cascading errors
set -o pipefail   # Unveils hidden failures
set -o nounset    # Exposes unset variables
can_ping() {
    ping -c1 google.com &>/dev/null
if can_ping; then
    echo "Successfully pinged google"
else
    echo "Failed pinging google"
    wpa_gui
fi
I have put this code at the bottom of my kiosk.sh script and if I turn off the wifi, it starts wpa_gui. However, the wpa_gui stays in the background of the browser and so the user cannot really see the wpa_gui.
Any idea, how I can make it, so that the wpa_gui appears in the foreground?
