rwb
Get a screen with a rainbow coloured square on it; it doesn't do anything.
Sun May 09, 2021 7:46 pm
Bought a Pi Zero.
Bought a Transcend branded 4GB Micro SD card
Downloaded and installed Raspberry Pi Imager(Windows 10)
Wrote and verified Raspberry Pi OS Lite (32-bit)
Plugged in HDMI via adapter and keyboard via USB OTG cable.
Plugged in power.
Can this be fixed or is it just broken and I need to send it back?
RaspbianUser1
Re: It doesn't work
Mon May 10, 2021 12:11 am
When reaching the square does it do anything else?
Does it shutdown, does it repeat booting itself, or just sit there on the screen
Ps, don’t swear here
Running with a Raspberry Pi 4B 4GB with Raspberry Pi OS with MATE Desktop
Why not overclock, push some more performance out of your computer!
Think before you delete something a stranger on the internet told you to.
Imperf3kt
Contact: Twitter
Re: It doesn't work
Mon May 10, 2021 12:55 am
Raspbian lite is a gui-less operating system, you probably want the desktop version but that will require at least 5GB of space, so will require an 8GB or larger card.
55:55:44:44:4C
52:4C:52:42:41
Gavinmc42
Re: It doesn't work
Mon May 10, 2021 2:27 am
Usually means the uSD card has issues.
On other Pi's you see the red power led go on and then the green led flickers when it reads the uSD.
A bit of practice and it is easy to spot when the uSD is going to fail.
Sometimes it can just be a dirty contact, I just give them a polish/rub with my thumb.
The thumbprint texture is enough to clean the contacts.
4GB is old card, hope you didn't pay much for it.
I prefer Sandisk 16GB A1 at the moment.
I'm dancing on Rainbows.
Imperf3kt
Contact: Twitter
Re: It doesn't work
Mon May 10, 2021 3:46 am
Its a normal part of the boot process, it should only last a second or so though.
55:55:44:44:4C
52:4C:52:42:41
Gavinmc42
Re: It doesn't work
Mon May 10, 2021 7:11 am
I think it means it has booted from the uSD but has not found a kernel?
I got something like that a few weeks ago, config etc was fine but the kernel was corrupted?
Re: It doesn't work
Mon May 10, 2021 8:06 am
Oh dear, that's about a quarter or eighth of the size you need.
Get a 16GB or 32GB SDCard to replace it.
deepo
Re: It doesn't work
Mon May 10, 2021 8:51 am
And, as posted above, don't use the Lite version if you want to display any graphics.
The Lite OS will only give you a console to login to.
