claben
Problem on the wifi connection with the router
Sun May 09, 2021 3:10 pm
I have a Raspberry Pi 3 Model B +, with raspbian, that has a problem on the wifi connection with the router; if the router turns off or restarts the raspberry does not reconnect and to activate the wifi connection I have to turn off the raspberry and turn it back on.
Can someone help me.
Claudio
Claudio
Raspberry PI2 Model B
neilgl
Re: Problem on the wifi connection with the router
Sun May 09, 2021 3:27 pm
That is not normal. Have you made any changes to the standard network settings on the raspberry Pi OS running on the pi?
claben
Sun May 09, 2021 3:33 pm
I only entered a static ip
Claudio
neilgl
Sun May 09, 2021 4:13 pm
Maybe undo those changes so that the pi gets an ip address from the router via DHCP (i.e. not using the static ip) then test the router on/off restart ?
(The best way to get a "static ip" for your pi is to configure that in your router using the "address reservation" table or similar)
claben
Sun May 09, 2021 4:53 pm
ok, thanks, I'll try and let you know
Claudio
