0v3rl0rd
Connect to hidden ssid
Wed Apr 28, 2021 11:10 pm
Hi
I'm just setting up my new RPi4 with OpenMediaVault. I installed the latest Raspberry Pi OS Lite (VERSION="10 (buster)"), then flashed OpenMediaVault.
I'm following THIS tutorial from ExplainingComputers on YouTube.
What I want is to connect the RPi to my hidden WiFi - I know that hiding a network does not significantly increase security, but I want to set it up that way.
I did manage to connect it to my WiFi with SSID enabled, but when I disable the SSID broadcasting, it doesn't connect.
With some research I found a few suggestions:
1) sudo nano /etc/network/interfaces
2) sudo nano /etc/wpa_supplicant/wpa_supplicant.conf
But when I open those, they are almost empty.
With the first (sudo nano /etc/network/interfaces) I get the following output:
# This file is auto-generated by openmediavault (https://www.openmediavault.org)
# WARNING: Do not edit this file, your changes will get lost.
# interfaces(5) file used by ifup(8) and ifdown(8)
# Better use netplan.io or systemd-networkd to configure additional interface stanzas.
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
With the second (sudo nano /etc/wpa_supplicant/wpa_supplicant.conf) I get this:
update_config=1
I tried editing the wpa_supplicant.conf to this:
update_config=1
network={
	scan_ssid=1
	ssid="LIMITED"
	psk="1234"
Any suggestions?
klricks
Re: Connect to hidden ssid
Thu Apr 29, 2021 4:33 pm
update_config=1
network={
	scan_ssid=1
	ssid="LIMITED"
	psk="1234"
Any suggestions?
Your country code is missing.
B.Goode
Thu Apr 29, 2021 4:52 pm
Any suggestions?
You could refer to the usually-reliable information published by Raspberry Pi themselves -
https://www.raspberrypi.org/documentati ... ess-cli.md
(It does mention both the option needed for a hidden SSID, and the necessity for a Country Code.)
0v3rl0rd
Fri May 07, 2021 12:17 am
[quote=You could refer to the usually-reliable information published by Raspberry Pi themselves -
I added the country code. Now it looks like this:
network={
	scan_ssid=1
	ssid="LIMITED"
	psk="1234"
        country=HR
But it still doesn't connect when the SSID is hidden :/
HawaiianPi
Fri May 07, 2021 12:40 am
Country code doesn't go in the network block.
update_config=1
country=GB
network={
	scan_ssid=1
	ssid="WiFi SSID"
	psk="WPA/WPA2 passphrase"
Fri May 07, 2021 8:19 am
You also need
bssid=ca:fe:de:ad:be:ef
with the MAC address of your access point in your network={} block.
0v3rl0rd
Fri May 07, 2021 10:14 pm
You also need
I moved the country code where it's supposed to be now.
I also added the MAC of my router inside the "network={}" block.
update_config=1
country=HR
network={
        bssid=CA:FE:DE:AD:BE:EF
	ssid="LIMITED"
        scan_ssid=1
	psk="1234"
Still no success. Just a reminder: I can connect to that same WiFi when SSID broadcast is enabled in router options. When selecting "hide SSID", no WiFi connection with my Pi4.
bls
Fri May 07, 2021 10:23 pm
You also need
update_config=1
country=HR
network={
	ssid="LIMITED"
        scan_ssid=1
	psk="1234"
Is there any useful information in the system log? sudo journalctl -b | grep wpa and post here in code tags.
Pi tools:
Quickly and easily build customized-just-for-you SSDs/SD Cards: https://github.com/gitbls/sdm
Easily run and manage your network's DHCP/DNS servers on a Pi: https://github.com/gitbls/ndm
Easy and secure strongSwan VPN installer/manager: https://github.com/gitbls/pistrong
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
0v3rl0rd
Fri May 07, 2021 10:26 pm
Hi.
Here is C/P from the "sudo journalctl -b | grep wpa":
May 07 23:18:49 raspberrypi wpa_supplicant[662]: Successfully initialized wpa_supplicant
May 07 23:18:49 raspberrypi wpa_supplicant[651]: Successfully initialized wpa_supplicant
May 07 23:21:25 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:21:32 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:21:40 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:21:47 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:21:55 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:03 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:07 raspberrypi sudo[923]:       pi : TTY=pts/0 ; PWD=/home/pi ; USER=root ; COMMAND=/usr/bin/nano /etc/wpa_supplicant/wpa_supplicant.conf
May 07 23:22:10 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:19 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:27 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:34 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:42 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:49 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:22:57 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:05 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:12 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:20 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:27 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:35 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:43 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:50 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:23:58 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
May 07 23:24:05 raspberrypi wpa_supplicant[662]: wlan0: Failed to initiate sched scan
bls
Fri May 07, 2021 10:34 pm
Hi.
Obviously it didn't connect because there's a problem. Taking a quick look at your wpa_supplicant.conf, it appears that you've lost the ctrl_interface line, which is probably why you're seeing the above in the log. Here's what it should look like:
update_config=1
country=HR
network={
	ssid="LIMITED"
        scan_ssid=1
	psk="1234"
PS Cafe DeadBeef sounds reallly appetizing :lol:
Pi tools:
0v3rl0rd
Fri May 07, 2021 10:48 pm
update_config=1
country=HR
network={
	ssid="LIMITED"
        scan_ssid=1
	psk="1234"
Sorry, my bad. I just didn't copy the "ctrl-interface..." part here - it does exist.
I tried running the system log command again and I got this:
pi@raspberrypi:~ $ sudo journalctl -b | grep wpa
May 08 00:40:23 raspberrypi systemd[1]: Created slice system-netplan\x2dwpa.slice.
May 08 00:40:29 raspberrypi wpa_supplicant[646]: Successfully initialized wpa_supplicant
May 08 00:40:29 raspberrypi wpa_supplicant[665]: Successfully initialized wpa_supplicant
May 08 00:41:03 raspberrypi wpa_supplicant[646]: wlan0: Failed to initiate sched scan
May 08 00:41:11 raspberrypi wpa_supplicant[646]: wlan0: Failed to initiate sched scan
May 08 00:41:19 raspberrypi wpa_supplicant[646]: wlan0: Failed to initiate sched scan
May 08 00:41:26 raspberrypi wpa_supplicant[646]: wlan0: Failed to initiate sched scan
May 08 00:41:34 raspberrypi wpa_supplicant[646]: wlan0: Failed to initiate sched scan
bls
Fri May 07, 2021 11:04 pm
update_config=1
country=HR
network={
	ssid="LIMITED"
        scan_ssid=1
	psk="1234"
Running out of ideas. Check that there is only one wpa_supplicant running pgrep -a wpa. If there's more than one, Kill the one with the lowest PID. Then sudo systemctl restart dhcpcd.
If there's only one, then the next thing to try would be to get some additional debug output from wpa_supplicant:
sudo systemctl stop dhcpcd          # This should shut down wpa_supplicant
sudo pgrep -a wpa                       # Make sure it's shutdown
sudo /sbin/wpa_supplicant -u -s -d -d -O /run/wpa_supplicant # Each -d increases the debug level
Copy the output from running wpa_supplicant with a few -d switches and post it here.
Pi tools:
0v3rl0rd
Fri May 07, 2021 11:24 pm
So, here is some output when running commands You suggested.
There were two wpa_supplicant running and I killed the one You said.
When running the last command, there is no output as You can see.
pi@raspberrypi:~ $ pgrep -a wpa
647 /sbin/wpa_supplicant -c /run/netplan/wpa-wlan0.conf -iwlan0
666 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
pi@raspberrypi:~ $ kill 647
-bash: kill: (647) - Operation not permitted
pi@raspberrypi:~ $ sudo kill 647
pi@raspberrypi:~ $ sudo systemctl restart dhcpcd
Failed to restart dhcpcd.service: Unit dhcpcd.service not found.
pi@raspberrypi:~ $ sudo systemctl stop dhcpcd
Failed to stop dhcpcd.service: Unit dhcpcd.service not loaded.
pi@raspberrypi:~ $ sudo pgrep -a wpa
pi@raspberrypi:~ $ sudo /sbin/wpa_supplicant -u -s -d -d -O /run/wpa_supplicant
pi@raspberrypi:~ $
bls
Fri May 07, 2021 11:32 pm
Let's try this one more time.
  • Kill ALL running wpa_supplicants (pgrep -a and then kill each and every one of them)
  • sudo /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
And paste the output. If running wpa_supplicant doesn't produce any output on your terminal, then something else is wrong. If that's the case, reboot and try the steps above again. If that doesn't do it, then... :roll:
EDIT: I reread the thread and I see that you aren't using dhcpcd. Too bad. I (and I'd guess most others here) haven't used the old networking stuff you're using in quite some time. I've updated the steps above.
Pi tools:
Sat May 08, 2021 8:44 am
It's the Voodoo café, there's a bit of a hex on it.
0v3rl0rd
Sat May 08, 2021 4:48 pm
About DHCPCD - to be honest, I have no idea what that is. I do have some experience in using Ubuntu, but all in all I'm new to Linux, especially the command line and the logic behind it.
It's my first try in using RPi at all. I'm trying to build a home NAS using RPiOS Lite and OMV on top of it.
Anyway, while I was waiting for a response I tried something (and after that I went to sleep... it was too much of a command line in one go for me :D ):
1. I formatted the MicroSD card
2. flashed Raspberry OS LITE
3. edited the wpa_supplicant to the simplest form for hidden network (even excluded the "country" line):
update_config=1
network={
	scan_ssid=1
	ssid="LIMITED"
	psk="1234"
And it works.
Then I tried installing OpenMediaVault, and upon finishing the script resulted with this:
    Function: cmd.run
      Result: False
     Comment: Command "netplan apply" run
     Started: 13:55:22.069676
    Duration: 282.54 ms
     Changes:
              pid:
                  1659
              retcode:
                  78
              stderr:
                  /etc/netplan/20-openmediavault-eth0.yaml:16:1: Invalid YAML: aliases are not supported:
              stdout:
Summary for raspberrypi
Succeeded: 8 (changed=8)
Failed:    1
Total states run:     9
Total run time:   5.058 s
Error applying network changes.  Skipping reboot!
So I guess that the problem is with how OMV handles the ethernet/WiFi connections, because the hidden WiFi connection works normally when flashed fresh RPiOS Lite, and doesn't work after flashing OMV.
Because of the error mentioned above (when installing OMV), I tried:
sudo nano /etc/netplan/30-openmediavault-wlan0.yaml
... and the output is:
network:
  wifis:
    wlan0:
      dhcp4: true
      dhcp6: false
      link-local: []
      access-points:
        "LIMITED":
          password: "1234"
So my best guess is that OMV uses that file instead of the wpa_supplicant when connecting to WiFi, so I think that the settings must be changed there (after installing OMV)... must find how.
LTolledo
Sat May 08, 2021 11:11 pm
that's one big reason to stay away from OMV....(for now)
for network sharing... I used the simplest method.... just plain old reliable samba on top of lite OS...(others prefer NFS on top of lite OS)
Some people be like:
Return to “Beginners”
