GarraTheWinnie
A DS18B20 with 5v
Thu Apr 22, 2021 10:19 pm
Hey everyone.
I’m using a DS18B20 Thermometer. Due to how I have my project set up, it made sense to use the 5v to power it, and use a LLC to convert the logic down to 3.3v
I set it up, and it didn’t work. I then tried hooking it up without the LLC and it worked perfectly.
I checked the data sheet, and from what I can tell, it should be sending out a 5v logic signal. Assuming it is doing that, is there any danger in this?
Does anyone know if it’s automatically convert the logic to 3.3?
joan
Re: A DS18B20 with 5v
Thu Apr 22, 2021 10:22 pm
It is okay to power with 5V. Make sure the data line pull-up is to 3V3.
GarraTheWinnie
Thu Apr 22, 2021 10:27 pm
I’m not sure what you mean. I just tested data line, and I got 4.5
GarraTheWinnie
Thu Apr 22, 2021 10:39 pm
Is this what you mean?
What is the danger with leaving it how it is, if it’s working?
Imperf3kt
Contact: Twitter
Fri Apr 23, 2021 12:36 am
Why is gpio 4 connected to 3v3 via a resistor?
55:55:44:44:4C
52:4C:52:42:41
Rose tinted glasses are difficult to see through.
GarraTheWinnie
Fri Apr 23, 2021 2:09 am
1wire needs the data line to be wired parallel to a power source with a 4K resistor
GarraTheWinnie
Fri Apr 23, 2021 3:40 pm
This work ended up working.
It’s now coming out at the right voltage
pcmanbob
Fri Apr 23, 2021 4:36 pm
Because the data pin on the sensor is an open drain output so you have to apply a pull up to be able to read the data.
as the pi gpio is not 5V tolerant if you apply a 5V pull up you will end up latching gpio4 high and so damage your pi , eventually the pi will likely stop working all together.
joan
Fri Apr 23, 2021 4:37 pm
Your schematic looks correct. I'm not sure why you read 4.5V on the data line. The data line is open drain and should be at the same voltage as the pull-up (which must be 3V3 on the Pi).
pcmanbob
Fri Apr 23, 2021 4:48 pm
I think the OP was originally using a 5V pull up as they were powering the sensor with 5V.
4.5V would probably be about right if using a 4.7K resistor for the pull up.
joan
Fri Apr 23, 2021 5:02 pm
Yes, I confused myself.
Return to “Beginners”
