Joonius
unable to exit openbox
Mon Apr 19, 2021 10:57 am
I don't know how but I accidentally entered openbox
I was trying to set the default python version
but all of a sudden I wasn't able to open the terminal
so I rebooted my pi and boom I'm in openbox
I didn't know what was going on, my taskbar is gone and ctrl + alt + t to open the terminal also doesn't work the only thing that was able to do was right click
when I right clicked it showed some options
I was able to open all apps using it and also there was the exit option
I click it, and it showed a message saying Are you sure you want to exit Openbox? so I clicked exit and the system rebooted
so I logged in again with my account, but nothing changed !!!
OS: raspberry pi os 64 bit
Raspberry pi: rpi4 b
I'm really desperate I wasn't able to find any good pieces of information online
someone, please help me!!! I'm a beginner!!!
klricks
Re: unable to exit openbox
Mon Apr 19, 2021 3:24 pm
Do not try to exit openbox. OB is needed......
Did you change the contents of autostart? If so make sure autostart has these 2 lines:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
Note there is no Python default to be set.
When you need Python 2 then use python or python2
When you need Python 3 then use python3
kerry_s
Mon Apr 19, 2021 7:41 pm
you say exactly what you did/changed
Joonius
Mon Apr 19, 2021 11:57 pm
I didn't edit autostart I just checked if those two lines were there, and they were there
and what do you mean by do not try to exit openbox??? I need to exit it
I want my normal pi DE back
kerry_s
Tue Apr 20, 2021 12:08 am
is "appearance settings" in that desktop menu.
if so open it> default tab, medium
then reboot
klricks
Tue Apr 20, 2021 12:59 am
Openbox must be running. The DE LXDE runs on top of OB. Closing OB puts you deeper in the 'hole'.
Try running these 2 commands from the OB terminal:
lxpanel --profile LXDE-pi &
pcmanfm --desktop --profile LXDE-pi &
Joonius
Tue Apr 20, 2021 1:34 am
How do I open the OB terminal???
kerry_s
Tue Apr 20, 2021 1:39 am
right click on the desktop
klricks
Tue Apr 20, 2021 1:40 am
Right click on the screen and select terminal.
Joonius
Tue Apr 20, 2021 1:46 am
I ran the commands and I selected defaults for medium in appeance setting and rebooted
and the taskbar is back but it's still not the classic raspberry pi DE
kerry_s
Tue Apr 20, 2021 2:04 am
press print & post the pic
selecting default should have reset everything back to stock, like when you first install.
unless you installed something that is overriding the settings.
Joonius
Tue Apr 20, 2021 2:29 am
file:///home/Joonius/2021-04-20-052525_1920x1080_scrot.png
kerry_s
Tue Apr 20, 2021 2:49 am
that's default lxde, if i had to guess i would say you somehow changed the session log in, so it's not logging into lxde-pi, but lxde instead.
can't remember the command to change, let me google & get back to you.
Joonius
Tue Apr 20, 2021 2:55 am
ok thanks
kerry_s
Tue Apr 20, 2021 3:03 am
sudo apt install --reinstall raspberrypi-ui-mods
try that command & reboot
kerry_s
Tue Apr 20, 2021 3:14 am
might also want to try
sudo apt install --reinstall raspberrypi-sys-mods
Joonius
Tue Apr 20, 2021 3:18 am
it worked
but I'm unable to open the terminal
error message: Invalid menu directory 'System/lxterminal.desktop'
Joonius
Tue Apr 20, 2021 3:23 am
Wait!! It worked
it worked after a reboot
thank you guys for all the answers bye!!!
kerry_s
Tue Apr 20, 2021 4:53 am
that's good.
remember don't use lxde settings, raspberry is a modified lxde, but uses different settings/tweaks. only use what's in preferences.
