krok
Lxterminal new tab and run sh script
Fri Apr 16, 2021 2:22 pm
How to open a new Tab inside the current lxterminal and run .sh script in this new Tab?
If I call
 lxterminal --tabs=1,2 -e ./script.sh
it will open a new lxterminal with a tab and runs the script there, but I want to open only a new Tab in current lxterminal and run it here.
Something like this:
this lxterminal --tab --title="newTabName" -e "./script.sh"
Thank you.
klricks
Re: Lxterminal new tab and run sh script
Sat Apr 17, 2021 1:55 pm
I don't believe lxterminal supports that. It's not in the man page.
One option is to install and use xdotool scripting to send keyboard /mouse commands.
Or maybe a different terminal program can be used?
Why not just open a 2nd lxterminal window?
GlowInTheDark
Sat Apr 17, 2021 2:12 pm
Or user screen or tmux...
This is, of course, a totally different approach to the problem, so maybe not what OP is looking for, but it will give you much the same visual effect as having things running in multiple tabs, and a lot more control than you would get trying to scale Mt. Lxterminal.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
krok
Sat Apr 17, 2021 3:00 pm
I need to open about 20 windows :(
Sure, do you have any tip for raspberry pi 8gb? (Raspbian GNU/Linux 10 (buster))
Thank you.
    rpdom
    Sat Apr 17, 2021 3:08 pm
    I use xfce4-terminal. The --tab option just opens another tab in the current window.
    Unreadable squiggle
    RaspbianUser1
    Sat Apr 17, 2021 7:35 pm
    I use terminator, it allows you to have multiple terminals in 1 windows and in tabs of them
    ALL in the same app/process
    Running with a Raspberry Pi 4B 4GB with Raspberry Pi OS with MATE Desktop
    Why not overclock, push some more performance out of your computer!
    Think before you delete something a stranger on the internet told you to.
    krok
    Fri Apr 23, 2021 1:50 pm
    Is there a way how to set a name (title) for the new Tab?
    RaspbianUser1
    Fri Apr 23, 2021 9:16 pm
    Create the tab, double click on the name (where you click to change tab), type new name them
    krok
    Fri Apr 23, 2021 10:03 pm
    I mean from the command line 😉
    RaspbianUser1
    Fri Apr 23, 2021 10:27 pm
    Ctrl+Alt+A but that closes the window for me so I remapped the keybind to ctrl+ alt+N
    krok
    Fri Apr 23, 2021 10:42 pm
    No no... I mean
    terminator --new-tab "newTabName" -e ./my script.sh
    RaspbianUser1
    Fri Apr 23, 2021 11:11 pm
    The man page references using -T “words” to set a title
    Maybe you can do some personal research
    krok
    Sat Apr 24, 2021 6:48 am
    That -T is not working -it is for window, not for tab- that is why why I'm asking...
    Return to “Beginners”
