Moris526
Reading pin
Thu Apr 15, 2021 9:27 pm
Hi.
Im using RAspberry to control Adafruits Neotrellis button/led board https://learn.adafruit.com/adafruit-neotrellis
Im trying to read the interupt wire on the neotrellis board with this code:
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
INPUT_PIN = 4
GPIO.setup(INPUT_PIN, GPIO.IN)
while True:
           if (GPIO.input(INPUT_PIN) == True):
                    print('1')
           else:
                    print('0')
But I get a stream of ones from the beginning, and nothing changes when I press a button.
Any idea? Not a programmer, as you can see.
neilgl
Re: Reading pin
Thu Apr 15, 2021 10:34 pm
How have you got the neotrellis connected to the pi and how is it powered?
Moris526
Re: Reading pin
Thu Apr 15, 2021 10:47 pm
Pi powered via Usb.
Neotrellis via 5v Power supply
interrup wire connected to GPIO 4 , an also Ground
joan
Re: Reading pin
Thu Apr 15, 2021 10:56 pm
The 1-wire bus uses gpio 4. Make sure it's not enabled in /boot/config.txt
neilgl
Re: Reading pin
Fri Apr 16, 2021 8:18 am
Yes and to avoid it, change to using GPIO 21 (say) . See https://pinout.xyz/
The adafruit doc says “ The pad labeled INT on the NeoTrellis board will be pulled LOW when an event the user has subscribed to is detected”
So in your code, set the GPIO (21) to have a pull-up. It will then stay at 3.3V (logic 1) until the interrupt occurs and takes it to 0V (logic 0).
Test it by temporarily disconnecting the trellis interrupt and using a wire or button/switch , take gpio21 to ground (0V).
Moris526
Re: Reading pin
Sun Apr 25, 2021 3:00 pm
Does this would set the GPIO (21) to have a pull-up?
GPIO.setup(21, GPIO.IN, pull_up_down=GPIO.PUD_UP)
I can make it work with a button.
I guess is a Neotrellis thing...
neilgl
Re: Reading pin
Sun Apr 25, 2021 9:29 pm
It does. And you have GPIO.setmode(GPIO.BCM)
Moris526
Re: Reading pin
Mon Apr 26, 2021 2:28 pm
Thank you
Mia1011
Re: Reading pin
Mon Apr 26, 2021 4:41 pm
Thanks for this useful for me
Return to “Beginners”
